Low oil temp M5 f10 on autobahn - BMW M5 Forum and M6 Forums
F10 M5 Discussion 2010- Discussion about the next upcoming generation M5 based on the next generation 5-series, the F10.
post #1 of 3 Old 11th March 2019, 11:54 PM Thread Starter
M5e60_87
M5e60_87's Avatar
Hi!
I have a M5 F10 year modell 2012-3 production. And I have notic a strange behavior with oil temp. The oil temp travels a bit, from 80-95 degrees C. I do not follow the gauge because it is not correct allways.
The coolant is almost allways at 105 degrees C. It drops a bit when you floor it and back to 105 like normal.
But the oil temp goes very low when I cruis on autobahn, all from 110km/h to 180km/h it is very low. I am not used to it from my old M5 e60 when it allways stayed at 95-100ish.
When I drive on city or speeds up to 90km/h it stayes stabil at 88-93 degrees C the oil temp.
Is this normal? Should it be like this? Oil level sensor also works good and no fault codes. No fault codes or something like that. Car runs perfect really. Here is a picture down below. This is like 2-3 hours of driving and gauge is that low. From what I have calculated, the first pin from 70 degrees is like 95ish degrees. So that must be like 80 on that speed.
Hope someone have any input on this.
Regards
Skickat från min iPhone med Tapatalk
M5 e60 Sepang Bronze. MDM - 500 sport. 5th gear speed
M5e60_87 is offline
post #2 of 3 Old 14th March 2019, 07:27 PM
technician117
technician117's Avatar
What is the ambient air temp? (outside air) That temp looks fine to me if cruising for an extended period of time and the outside temp is cooler or cold.
Edit - my bad, I realized I can see the outside air is 17C. The oil cooler is large on this car. That said, the engine manual states the oil thermostat opens at 100C. Maybe you have a problem where it is not closing enough, but with low load conditions for so long, it is possible the engine isn't generating enough heat to warm the oil further?
Tim
2013 M5 Imperial Blue/Silverstone II, 6MT 64k miles
2000 Anthracite daily driver
UUC dssr and shifter
Supersprint headers with Tubi catback
Jailbreak tuning
Dinan 3.45 JED lightened flywheel
286,000 miles and counting
'00 Imola/Imola 107k stock
'00 Silverstone/Silverstone 129k (SOLD)
technician117 is offline
post #3 of 3 Old 14th March 2019, 07:46 PM Thread Starter
M5e60_87
M5e60_87's Avatar
Yes, should be a normal sensor to change out? I have no fault codes or something like that.
it is only at speeds from 110km/h it drops in oil temp. Under that it goes up. Some say it is normal, some say water thermostat but that is also good and it feels like it should behave diffrent if it was water thermostat.
M5e60_87 is offline
oil temp high in slow traffic 1day E34 M5 Discussion 61 2nd March 2014 10:31 AM
Engine Oil FAQ ard E39 M5 and E52 Z8 Discussion 115 28th November 2011 06:47 PM
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 03:43 PM
DIY Dummies Guides to Oil Change using Fluid Extractor HDClown E39 M5 and E52 Z8 Discussion 0 18th September 2005 12:46 AM
