BMW M5 piston ring failure one cylinder possible costs - BMW M5 Forum and M6 Forums
F10 M5 Discussion 2010- Discussion about the next upcoming generation M5 based on the next generation 5-series, the F10.
 1Likes
  • 1 Post By Craze
post #1 of 8 Old 10th March 2019, 09:16 AM Thread Starter
janismm88
Was diagnosed by BMW main dealer cylinder 7 piston ring failure and no compression in cylinder 7, others seems fine. I know it's major task but in this case it's only 28000 miles so it's not that all engine worn out. Car was ECU tuned to 680bhp. I'm just thinking what parts most likely need to replace only piston ring or something else. Car is not much driven after this maybe 10 miles. I know if it was wear and tear it would be huge job and many parts need replacing. But this car is low mileage and I think other pistons and cylinders are fine. Of course tomorrow I go to mechanic independent specialist but today got offer to sell but for very low price just thinking if this could be few thousand job like 2-3 thousands or any case 10000+ job...?
janismm88 is offline
post #2 of 8 Old 10th March 2019, 09:37 AM
Craze
Im not an expert but id imagine heads off and reco etc possibly 10k job
While you are in their id get proper built motor and not a repair
Craze is offline
post #3 of 8 Old 10th March 2019, 09:42 AM Thread Starter
janismm88
Ok but you think it's not cheaper if only one cylinder fail only one piston ring need changed and other parts 99% should be fine
post #4 of 8 Old 11th March 2019, 07:18 PM
technician117
technician117's Avatar
Before you do anything, get that second opinion from an independent shop that you mentioned. I would have them confirm no compression and then scope the cylinder to look for damage to the cylinder wall. If the wall is scored, you're probably better off using that engine as a core to a rebuilder and buying a new rebuilt replacement. If the wall looks clean, than set of rings could probably be replaced and put back together but I don't know the nuances of these engines to know for sure. You might want to figure out what caused the failure too. Either way, the entire engine should be torn down and cleaned because the broken ring pieces/metal are spread throughout the engine now.
Tim
2013 M5 Imperial Blue/Silverstone II, 6MT 64k miles
2000 Anthracite daily driver
UUC dssr and shifter
Supersprint headers with Tubi catback
Jailbreak tuning
Dinan 3.45 JED lightened flywheel
286,000 miles and counting
'00 Imola/Imola 107k stock
'00 Silverstone/Silverstone 129k (SOLD)
technician117 is offline
post #5 of 8 Old 13th March 2019, 05:26 PM
peterman1234
peterman1234's Avatar
If your planning on doing the work yourself it will cost you around 3000 if everything else is still intact. High chance that the wall is scored and will need a sleeve for that cylinder. If your going to push the engine and get it hot you will need better rings with a larger gap.
peterman1234 is offline
post #6 of 8 Old 17th March 2019, 05:23 PM
M5 London
M5 London's Avatar
I'd approach your ECU tuner first....
F06 M6 Gran Coupe 2015 - Imperial Blue Xirallic / Silverstone Merino
E39 M5 1999 - Carbon Black Metallic / Caramel Nappa Heritage Leather - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
E34 M5 1995 - Arctic Silver / Black Leather
E30 M3 1987 - Diamond Black Metallic / Black Leather
M5 London is offline
post #7 of 8 Old 18th March 2019, 04:58 PM
herrubermensch
I would recommend strongly against any kind of partial rebuild, as they never turn out well. S63 rebuilds can be done reasonably inexpensively. Raza at RK Autowerks in Dallas does them quite efficiently. We probably will start doing them ourselves in the next 12-18 months.
--Peter
herrubermensch is offline
post #8 of 8 Old 18th March 2019, 06:03 PM
Al59751
Al59751's Avatar
Its never just a few thousand, throwing that number out there is nothing different than trying to hit a powerball. Its close to 30 hours labor just to do the engine job, there goes your 3k fix. This will without any doubt be over 10k regardless where you go. An independent shop will give you a great deal to pull it all apart to get you in the door. Then will tell you its that same 10k+ job.
At which point you will probably realize its not really worth it because you went in without realistic expectations and under budget, except at that point your cars engine will be in the trunk and worth even less...at least now it runs...sort of. If you dont realistically feel content with spending 10kish on fixing it, let it go.
Heck tuned to 600+. You got a chunk of ring land missing and probably cylinder gone with it. Downright Zero compression on " worn " rings doesn't happen.
Heck i'll buy it if price is right. Drop your contact.
Al59751 is offline
BMW X5 M and X6 M "...made up for the end of the production cycle of the BMW M5 Sedan, which has been one of the cornerstones of BMW M automobile salesup to now" : BMW M Press Release: More joy in top-level performance: the product range of Gustav E60 M5 and E61 M5 Touring Discussion 7 15th February 2010 07:45 PM
M5 and M6 will get new mirrors,EfficientDynamics, I-Drive, 80 GB HD based navigation / media storage (3D mapping) + M6 Competition Package w active suspension Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 4th August 2008 05:12 AM
List: Sultan of Brunei's complete car collection, no M5 but an Alpina Gustav GTBoard.com: General Sportscars 74 15th April 2008 11:04 PM
