DCT Clutch Problems - BMW M5 Forum and M6 Forums
F10 M5 Discussion 2010- Discussion about the next upcoming generation M5 based on the next generation 5-series, the F10.
 13Likes
LinkBack Thread Tools Rate Thread
Old 3rd June 2016, 07:22 PM Thread Starter
Kelster
Registered User
Kelster's Avatar
DCT Clutch Problems
When manually downshifting at highway speeds (>60 mph) the F10 rev matches and engine braking begins and then inexplicably the clutches disengage. The net result is that the F10 coasts and the revs stay elevated. Application of throttle is required to re-engage clutches. This phenomena will also occur occasionally while cruising at higher rpms. BMW of Manhattan has finally conceded that the F10 hasn't been fixed and will enter the problem in PUMA.
Has any one else experienced this DCT clutch problem? TIA
Kelster is offline
Old 3rd June 2016, 10:32 PM
100%Cocoa
100%Cocoa's Avatar
100%Cocoa is offline
Old 3rd June 2016, 11:13 PM Thread Starter
Kelster
Registered User
Kelster's Avatar
Originally Posted by 100%Cocoa View Post
What mileage is your car? And do you have any after market tune? Thanks.
17K miles. Has Dinantronics Stage 2 which was removed before testing to eliminate the possibility of it being the source of the clutch malfunction.
Kelster is offline
Old 5th June 2016, 08:29 PM Thread Starter
Kelster
Registered User
Kelster's Avatar
Put 100+ miles on the F10 yesterday and have concluded that the second issue with the vehicle, maintaining speed & rpm after taking my foot off the accelerator is quite different than the erroneous clutch opening when attempting to use engine braking by manually down shifting. In this latter scenario the clutches are clearly staying engaged. Scheduled for round 3 with BMW of Manhattan on Monday June 13 after I come back from Timmayfest.
Kelster is offline
Old 14th June 2016, 04:46 PM Thread Starter
Kelster
Registered User
Kelster's Avatar
DCT Update
F10 is back with BMW of Manhattan as of yesterday. They have initiated a PUMA case and are downloading FASTA data from the ECU. Hopefully this will lead to a solution smh
Kelster is offline
Old 15th June 2016, 03:18 AM Thread Starter
Kelster
Registered User
Kelster's Avatar
Day 2 of the 3rd visit for the F10 to BMW of Manhattan's service department. Still no news. Losing patience. Sense of urgency lacking.
Kelster is offline
Old 15th June 2016, 03:55 AM
AGM5
AGM5's Avatar
Good luck my friend. Did they get a decent loaner for you this time?
///M - The most powerful & expensive letter in the alphabet
1 of 123 ANTHRAZIT METALLIC (397) / WALK NAPPA/SCHWARZ (M1SW)
Tuned by BMW Motorsports 4/2001, Bone Stock at 185,000 Miles. 355.78 WHP / 345.33 WTQ
2 facts you might not know: Ducks cannot fly and they nest in trees.
Updates:
BM53 Radio / Gen-13 ULF / OEM Sirius / MK-IV Navigation / Aux input / Intravee II / KCA-410c / KCA-420i / 5th Gen i-Pod Nano / CHA-S634 / Umnitza VXX Angel Eyes / F10 ///M5 Shift Knob /
Schmiedmann Shadow Chrome Grills / Rear Fog Lights
DIY: Retro-Fit Auxiliary Audio Input Harness /// DIY: E39 - BM53 & (BMW) Sirius Radio Retrofit /// DIY: E39 - Replacement of the Left and Right Firewall Covers
For Sale:
BMW Style 5 17" 2 Piece Wheels And Tires
AGM5 is offline
Old 15th June 2016, 01:24 PM Thread Starter
Kelster
Registered User
Kelster's Avatar
Thanks. Yes they did. A 320i. It's not half bad for driving in miserable traffic and worse roads in the Big Apple lol
Kelster is offline
Old 15th June 2016, 09:29 PM Thread Starter
Kelster
Registered User
Kelster's Avatar
Email from BMW of Manhattan confirming that they finally were able to see the clutches unexpectedly releasing on manual down shifts. What George Boutsikos told them weeks ago. PUMA also wants to obtain more FASTA data after (a) disconnecting Dinatronics and (b) putting different rims/tires on F10(!) I questioned (b) as these are factory 20" rims & Michelin PSS tires. I guess this is progress of sorts.
Kelster is offline
Old 16th June 2016, 10:37 AM
ur20v
ur20v's Avatar
The old different tyres/wheels routine hey... Good luk with this. Hopefully you will get a new DTC soon.
ur20v is offline
Rate This Thread
F10 M5 DCT Jerky and Clutch bite point Mark21287 F10 M5 Discussion 7 7th December 2018 04:25 AM
Clutch position sensor problems needs clutch change? mjac E60 M5 and E61 M5 Touring Discussion 11 27th March 2017 08:48 PM
BMW M DCT (Double Clutch Transmission) pictures rolren E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 7 3rd January 2009 08:32 PM
BMW M3 Convertible DKG / DCT Double Clutch Transmission 50-250 km/h and Launch Control LC Gustav E60 M5 and E61 M5 Touring Discussion 16 9th August 2008 08:55 PM
