DIY: 1998 E36 M3 Convertible Install with Maxspeedingrods: - BMW M5 Forum and M6 Forums
post #1 of 1 Old 21st October 2015, 10:52 AM Thread Starter
eklo
1. Support the rear of the car on jack stands at least 24” high.
2. Remove the rear wheels.
3. Remove the lower control arm bolts.
4. Remove exhaust and set aside.
5. Remove stabilizer sway bar and lower it out of the way leaving it connected to upper control arms.
6. Gently support final drive unit with floor jack.
7. Remove the 3 mounting bolts of the final drive.
8. Move the final drive up and back from the mounting points about ½” .
9. Remove the upper 18mm bolt from both old control arms and save the bolt and captive nut for later reinstall.
10. Replace the old control arms and adjust each new arm to match the one it is replacing.
11. Install the upper end of both arms using the existing bolts and captive nuts. (Do not torque at this time!)
12. Reinstall all three final drive mounting bolts and then torque to specs.
13. Reattach stabilizer bar.
14. Attach new lower control arms at ball joints but do not tighten.
15. Install rear wheels.
20. Lower car and remove jack stands.
21. Shift transmission to neutral and manually move car about six feet in each direction to settle suspension.
22. Manually push car on ramps to raise rear of car.
23. Torque upper and lower control arm bolts to the specs in Bentley manual.
24. Raise car on jack stands AGAIN.
25. Reinstall exhaust per instructions in Bentley manual.
26. Take short test drive directly to alignment shop and align.
eklo is offline
DIY: Review: Maxspeedingrods E36 Coilovers eklo E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 16th September 2015 10:16 AM
M3 For Sale: Maxspeedingrods BMW 3 Series E36 Camber Plate Hankjim Parts / Other For Sale or Wanted 0 13th August 2015 07:47 AM
M3 For Sale: 1998 Technoviolet e36 4racing Cars For Sale or Wanted 3 25th June 2012 11:16 PM
FOR SALE: 1998 E36 M3 Convertible 5speed IMMACULATE 95BlackZ28 Cars For Sale or Wanted 4 5th December 2007 05:32 PM
1998 E36 M3 AA Supercharged ESP Owners Gallery 6 7th February 2003 10:59 PM
