PDC Failure - BMW M5 Forum and M6 Forums
post #1 of 3 Old 16th June 2019, 01:33 PM Thread Starter
London_e63
PDC Failure
Hi guys,
After recently solving an issue with my M6 I now have another. The PDC failure fault is showing up and no sensors are working at all. Anyone had this before, if so what was the solution?
London_e63 is offline
post #2 of 3 Old 16th June 2019, 05:18 PM
flacoramos
A single sensor failure disables the whole system. Need to check what error you have, will tell you which sensor needs replacement.
flacoramos is offline
post #3 of 3 Old 19th June 2019, 06:04 PM
mugenfoo
mugenfoo's Avatar
Easy . Just get the car plugged it, and the BMW (i personally like and use ISTA/D) diagnostics will tell you exactly which specific sensor is on the fritz (of if you have real rotten luck, the PDC module itself: possible but unlikely). Any one single bad sensor front or rear, will disable the entire PDC system until the fault is rectified. But once the faulty sensor is replaced, the system comes back online without any fuss. No need to perform any reset via the diagnostic software too (unless you want to clear off all the historical fault codes).
- M(ugen)Foo
From VTEC to VANOS
mugenfoo is offline
