Need Advice - Failed Vacuum Pump - BMW M5 Forum and M6 Forums
post #1 of 1 Old Today, 09:18 PM Thread Starter
14rshanahan
14rshanahan's Avatar
‘08 m6 with ~47k miles
Originally my car started to overheat...pulled over and turned her off to cool down. Turned the car back on and immediately get “engine malf: reduced power” Car was serviced at Indy replacing the failing radiator fan.
When I went to pickup the car, the reduced power was still there but overheating was fixed. Indy mechanic said he test drove it everything was fine the day before. He keeps the car and ends up replacing vacuum sensor and says everything is good, but yet again the reduced power immediately came on a second after turning her on when I went to pick her up.
Now I am being told the vacuum pump itself needs to be replaced, he said sometimes the pump will activate/turn on sometimes it will not. My third party warranty states vacuum pump is covered under Powertrain but they denied the request stating they don’t cover the “brake booster vacuum pump” but only the vacuum pump itself...is there even a difference between the two?
Was quoted $1180 + tax for the repair out of pocket is this a reasonable price?
14rshanahan is online now
DIY Fuel Pump and Fuel Filter replacement M5 Jed E60 M5 and E61 M5 Touring Discussion 26 9th May 2016 12:25 PM
M5 E60 gearbox pump issues andygtt E60 M5 and E61 M5 Touring Discussion 0 2nd June 2015 12:39 PM
Info needed on fuel siphon pump MPowrd E39 M5 and E52 Z8 Discussion 7 28th July 2012 07:32 PM
Think my fuel pump just bit the dust - looking for some general advice JoeFromPA E39 M5 and E52 Z8 Discussion 9 4th June 2012 06:43 AM
Advice on using 540i fuel pump for M5? ehssan_alkhiyami E39 M5 and E52 Z8 Discussion 15 1st September 2006 12:46 PM
