Big brake kit for the e63 ?? - Page 2 - BMW M5 Forum and M6 Forums
 3Likes
post #11 of 20 Old 28th February 2019, 04:08 PM
flacoramos
Originally Posted by TexaZ3 View Post
Am I the only one who thinks stock brakes look great and more than adequate/great for street driving?
I think stock are perfect for street. Pair with track pads and fluid and they work great at the track as well. Looks are alright: rotors are fine but calipers look a bit dated compared to newer cars.
Originally Posted by triksterut View Post
If you're going to spend any time on a track I think you'll find this is a really really necessary upgrade. Otherwise, yeah - totally cosmetic
Nah, the secret is on pads, fluid and cooling. I was looking into BBKs after suffering massive pad transfer at the track rendering my rotors useless, but then I saw several cars (M3s, hondas, etc.) running stock brakes and blueish/golden rotors. They were in fact stock brakes except for DTC70/60 pads. I followed their example at the next event and with DTC60 on all four corners brakes didn't fade, overheat or had pad transfer at all. And I was using BFG R1 tires. So pads, Castrol SRF and removing the front backing plates (for cooling) did the trick.
flacoramos is offline
post #12 of 20 Old 28th February 2019, 04:52 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
Weakest link in the OEM system is fluid, brake lines, and pads.
SRF, SS lines, and good track pads is a quick performance upgrade.
If the OP is looking for eye bling on a budget — paint the OEM calipers.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =162,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; MCS 2WNR motorsport coilover, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Nuke Performance fuel rail and pressure regulator, Carbon Fiber CSL intake; Lifeline Zero 360 FIA 3.0kg Novec fire suppression; Cool Shirt Pro Air/Water system; Euro RestoMod track car: caged, 6 point Schroth FIA harness, FIA Sparco Ergo & Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x9 BBS Style 42 w/Michelin Cup 2; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
Not-spec e30 racercar!!! Fully caged for wheel 2 wheel racing
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Last edited by Fiftytwoeighty; 28th February 2019 at 06:26 PM. Reason: Autocorrect incorrectly corrected SRF.
Fiftytwoeighty is offline
post #13 of 20 Old 28th February 2019, 05:13 PM
flacoramos
Forgot to mention, IMO DTC pads are not street friendly. Crazy squealing when cold or street driven and *NASTY* dust. Not cheap either. Guess that's why all the cars I was referring to were swapping pads at the end of the trackday.
post #14 of 20 Old 2nd March 2019, 02:16 AM
built240
built240's Avatar
Originally Posted by Awbimmer View Post
I really only bought my Stoptech all round for eye candy but since then I'm on a journey to install my supercharger next wknd lol! It's a slippery slope!!
They're literally no fade and I don't track mine.
Sent from my SM-G950F using Tapatalk
What wheels are those in the first picture with the red symbol on them?
For warranty purposes, all modification talked about on my M6 is for role play only. My M6 is currently 100% stock and the mods I am referring to are from a friends M6 i'm posting about. Thanks
built240 is offline
post #15 of 20 Old 29th March 2019, 06:55 AM Thread Starter
jvsantosmd
Recently found out that the E3 M6 Brembo big brake kits use either 380 or 405 mm rotors. ($9000 for all 4 wheels). Well, there's a Mercedes Benz SL55 AMG that uses 380X34 mm rotors, the same as the Brembo kits. The AMG Brembos are 8 pistons!! Can buy them used for $800.00. Haven't been able to find 4 piston calipers to go with the 380X28 rear rotors. (Go to 405 mm and will need 20"wheels).
Looking into buying a set of MB 8 piston calipers, Brembo rotors ($1500 for all 4) and 6 piston rears ($500).
Tried getting into the Brembo parts catalog to look up which calipers come in what kits, which calipers fit what car, it is not possible to get any information from anybody.
I am hoping anybody here reading has something to say beside telling me to spend $9000 in a brake kit that could be bought for $2800.
jvsantosmd is offline
post #16 of 20 Old 29th March 2019, 03:06 PM
Fiftytwoeighty
Give these guys a call.
https://www.zeckhausen.com/
I get all my brake related stuff from him.
~Woody
~I FRACKING!
~Viva La Wolfpack!
post #17 of 20 Old 29th March 2019, 03:50 PM
Trizzuth
Trizzuth's Avatar
Nope, I am in the same club as you. But I do wish they had far more bite when coming off the highway around 100, because the car is a tank and deserves to have brakes that stop it as quickly as the engine moves it! Could just not ever justify the exorbitant cost of a BBK when the stock calipers perform adequately (although not perfectly for the weight of the car IMO).
New (old): 2003 E39 M5 TiAG
Old: 2001 E46 330i Steel-Grey Metallic (Totalled)
Trizzuth is offline
post #18 of 20 Old 29th March 2019, 10:47 PM
flacoramos
Initial bite is easy to change with aftermarket pads. FYI I'm selling a set of hawk dtc60 pads. Not exactly street-friendly, but others have daily-driven them so...
post #19 of 20 Old 5th April 2019, 03:02 AM Thread Starter
jvsantosmd
Many things have happened: bought a set of Brembo caliper adapters for the E60-E63 chassis from a Brembo GT kit. Now have to figure out which rotors and calipers I need. The previous owner told me the calipers were very similar to the Corvette C5. Still checking that. Not that I doubt him, but I don't want to buy several sets to find out what fits.
Apparently the GT kit front rotors were 380mm (oem 374) rears 355 (oem 370). SERIOUSLY thinking on installing the oem front rotors with an aftermarket used rotors. Porsche Cayenne 380mm front, 355 rears. To my dismay, the 8 pot front calipers off a MB CLS 55 AMG use a 380 mm front rotor. Maybe I can go 8 pot...
May just upgrade the rear calipers to 4 piston Brembos and leave the fronts alone ?? (for now...)
As a last option, a coworker just got a 2018 M6 Grand Coupe. Question: can I retrofit the rotors and calipers from the 2018 model to the E63 chassis? May need 20" wheels, that's easy.
Any suggestions?
post #20 of 20 Old 5th April 2019, 03:24 AM
Bimmer_Pilot
Any suggestions?
Not sure on the mounting points for the Brembo adapters.
Cayanne rotors (or any Porsche) are the wrong hat offset, bore size, and lug pattern.
F12/13 6 series have a redesigned hub. They do not share the same mounting points as e63/e64 6 series and the rotor offset is different as well.
Bimmer_Pilot is offline
E60 For Sale: E60 M5 / E63 M6 Stop Tech big brake kit (BBK) front+ rear for sale Awbimmer Parts / Other For Sale or Wanted 8 3rd October 2017 02:50 PM
DIY: How To Fit The BMW Performance Brake Kit to an E39 M5 StreetDragster E39 M5 and E52 Z8 Discussion 71 29th August 2017 01:48 AM
.:Trinity Autosport:. AP Racing 6-Piston Big Brake Kit E39 [email protected]trinityautosport.com M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 2 9th August 2016 02:49 AM
Do I have a Dinan Big Brake Kit on my 91? Zen M E34 M5 Discussion 19 28th September 2008 07:01 AM
StopTech E46 M3 kit used in big brake test - $2,000 off! DZeckhausen M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 8 26th October 2004 05:58 PM
