Smg problems need help - BMW M5 Forum and M6 Forums
 5Likes
post #1 of 20 Old 12th November 2017, 05:17 AM Thread Starter
bxgeezy
I have a 2007 e64 Iím had a fault code for 4fa0 and 510d replaced the plcd and did a smg adaption now gettin error for clutch adaption active it is failing the first test on dis for clutch values any suggestions?
bxgeezy is online now
post #2 of 20 Old 12th November 2017, 05:31 AM Thread Starter
bxgeezy
Also the 4fa0 and 510d codes only pops up at high rpm car shifts good no slip drive good still
post #3 of 20 Old 12th November 2017, 07:55 PM
jcolley
jcolley's Avatar
slave cylinder is the usual cause for error failure of adaptation. Does it say "clutch disengagement position outside of tolerance?"
jcolley is online now
post #4 of 20 Old 13th November 2017, 12:09 AM Thread Starter
bxgeezy
Yes thatís the error itís giving me can the direction control valve also b the problem ? I been reading a lot of your threads about this
post #5 of 20 Old 13th November 2017, 12:20 AM Thread Starter
bxgeezy
Also will the transmission need to b drop to replace the slave cylinder ?
post #6 of 20 Old 13th November 2017, 12:59 AM
flacoramos
Trans must be dropped, and Jim has stated the clutch control valve is unlikely to fail.
flacoramos is offline
post #7 of 20 Old 13th November 2017, 01:21 AM Thread Starter
bxgeezy
Ok thanks
post #8 of 20 Old 13th November 2017, 06:16 PM Thread Starter
bxgeezy
Can someone send me part number for the slave cylinder ?
post #9 of 20 Old 13th November 2017, 06:21 PM
flacoramos
post #10 of 20 Old 14th November 2017, 03:19 AM Thread Starter
bxgeezy
I got a quote at a local Indy and they estimated for slave cylinder replacement 2000 called another Indy n was quoted 550 does this sound right? Quotes r for parts n labor
SMG problems SilverStone_M5 E60 M5 and E61 M5 Touring Discussion 12 21st January 2017 09:47 PM
Smg problems bz06er E60 M5 and E61 M5 Touring Discussion 0 25th May 2016 07:19 PM
How many are *NOT* having SMG problems? Amer E60 M5 and E61 M5 Touring Discussion 110 9th September 2007 05:07 AM
Have you had SMG problems with your M6? T Bone E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 39 8th April 2007 03:30 AM
SMG Problems - Who's had problems after the replacement? Phantomias33 E60 M5 and E61 M5 Touring Discussion 4 4th September 2006 02:23 AM
