2006 M6 Turn signal upgrade to 2008 LCI LED turn signals - Page 20 - BMW M5 Forum and M6 Forums
 20Likes
post #191 of 204 Old 26th October 2018, 12:08 AM
Awbimmer
@roseng , I had to shelf this DIY for a while as work took over however I do have a question if I may.
If I live in the UK but buying a used set of LCI LED turn signals from the US (from a US car ofcourse!), would the same wiring diagram apply? Or, would something more need to be catered for when putting the wiring together?
Awbimmer is offline
post #192 of 204 Old 27th October 2018, 11:05 AM
roseng
roseng's Avatar
The original came from France and it worked in my US spec car. I can't say if the UK car is different. Maybe look up the wiring diagram of both and compare.
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....14' F10/M-Sport White
Stainless Steel Brake Lines/Akebono dustless brake pads
lighting
: Custom Orion V4 LEDs installed in headlight assembly (thanks to Zerocks1) in place of AE fiber rings, remove yello reflector in the sides of the headlights. OEM LCI front and LCI rear lamps 6000K MTEC headlights, 6000K HID fog lights, welcome lights,Philips COB DRLs,Turning Lights, Welcome Lights, BMW Projector Door lighting.
Additional installed LEDsFront side markers, Doors, Foot wells, Center overhead lamps, Trunk, License plate lights, Enabled rear fog lamps (installed new European spec switch)
Wheels: OEM M6 chromed wheels, Michelin PSS tires , Red MGP caliper covers, Carbon Fiber center caps, Compact spare tire/jack kit (in trunk for long trips only)
Programming with NCS coding AEs as DRLs, High beams using main headlights, Enable fog lamps with high beams, Dash lighting always on, Digital speed on dash enabled, Fan marker LED on in auto mode, Enable tail lights for DRL, Windows up from key fob, Delete weather band from radio, Remove Nav warning splash screen, Remove all bulb warnings for LEDs, Remove Seat Belt Gong, Remove Door Open gong
Nav Screen and audio: CIC upgrade with Combox and new style iDrive controller with factory center console, video monitor adapter installed - allows on-screen video anytime, Rear camera on license plate, Rear camera on CAN BUS automatically on during reverse, Video in 1 – HDMI out from iPhone 5 phone for full iPhone on screen, (I used a HDMI to composite video convertor), Video in 3 – rear camera on full time,
Misc: Carbon Fiber Dash, Console, steering wheel controls, front and rear Roundels, etc., Upgrade custom rear view mirror with CA and compass, Remove yellow air bag warning on visors, Trunk mesh hold-down, trunk latch timing reprogrammed, BMW door lock pins, Schnitzer Pedals and foot rest. LCI AC controls.
roseng is offline
post #193 of 204 Old 28th October 2018, 10:43 PM
built240
built240's Avatar
What’s the cost to upgrade to the 2008+ lights?
For warranty purposes, all modification talked about on my M6 is for role play only. My M6 is currently 100% stock and the mods I am referring to are from a friends M6 i'm posting about. Thanks
built240 is offline
post #194 of 204 Old 22nd January 2019, 09:01 PM
Sondre
Originally Posted by roseng View Post
If you are handy with a soldering iron, or know someone who is, I can give you a DIY. PM me if you want details.
I would love a DIY if you still got it, send it by PM
Sondre is offline
post #195 of 204 Old 23rd January 2019, 01:06 AM
roseng
roseng's Avatar
CIC front blinker Wiring.pdf
This is this is the wiring diagram. Do a search for Mimi74 in this forum. There is a long thread in CIC upgrading. All the data is there. PM me if you have questions.CIC front blinker Wiring.pdf
lighting
roseng is offline
post #196 of 204 Old 6th March 2019, 08:53 PM
Carlsius
Thanks for your reply Roseng
I have fitted the LCI front indicators to my vehicle and made the exact same wiring as mimi74's diagram but I experience flickering when the car is running.
When I start the car everything is fine, but after around 30 sec the 2 DRL leds starts flickering and goes away. If I don't start the engine everything is fine.
Also when I use the indicator it could double flash in between the normal flashing, but other than that it works fine.
Any idea what it could be?
I have made Mimi74's wiring with 4 diodes(2 each light) and without resistors because it is coded.
All help is much appreciated
Carlsius is offline
post #197 of 204 Old 9th March 2019, 03:40 PM
roseng
roseng's Avatar
I remember something similar. Double check your diode polarity.
lighting
roseng is offline
post #198 of 204 Old 9th March 2019, 03:51 PM
Awbimmer
Anyone willing to make the wiring in exchange for £/$?
Yours truly,
A guy who can't make wiring.
Sent from my SM-G950F using Tapatalk
Awbimmer is offline
post #199 of 204 Old 9th March 2019, 05:28 PM
Carlsius
Thanks for the advice. I will order 4 new diodes and have them installed again and triple-check that it is correctly wired in.
But i noticed Mimi74 changed 2 or 3 wires location in the LMA(ligh module). Is that something that needs to be done? I haven't done anything other than coding and making the wiring :/
Carlsius is offline
post #200 of 204 Old 9th March 2019, 10:40 PM
bigpaul
bigpaul is offline
2006 M6 tail light upgrade to LCI LED's. whatheheck E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 153 20th August 2014 02:35 PM
E60 For Sale: LCI Tail Light Upgrade, Carbon Bits, Angel Eyes, Car Cover, CD Changer, Pre-LCI Headlight Stickers Falb Parts / Other For Sale or Wanted 12 17th February 2010 07:29 AM
Anyone do the LCI Headlight & Turn Signal Conversion yet? T Bone E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 23rd July 2008 04:29 PM
Turn signal won't turn off automatically J Irwan E39 M5 and E52 Z8 Discussion 9 22nd October 2007 11:09 AM
Regarding turn signal?? please help... Micsor/DK E39 M5 and E52 Z8 Discussion 1 1st February 2002 08:38 PM
