Improved Aux Input Sound Quality & Volume - BMW M5 Forum and M6 Forums
post #1 of 5 Old 13th March 2006, 10:48 PM Thread Starter
m_five
m_five's Avatar
Some people find that the sound quality (particularly the bass) & volume of the aux input isn't as good as it could be. My experience is if you rip your MP3 files using a high quality encoder at a reasonably high bit rate, and normalize volume (I use Exact Audio Copy w/ LAME encoder @256kbps VBR http://users.pandora.be/satcp/tutorials.htm and MP3Gain @ 94dB to volume normalize http://mp3gain.sourceforge.net/ ), this isn't a big issue, although the volume is noticeably lower. I recently saw a post on another forum that contained a mod that addresses this issue, and am happy with the results, so I thought I'd provide a DIY.
The aux input wiring harness contains (2) 220nF capacitors and a 300K-ohm resistor, which filter out low frequency and degrade sound output. Apparently, the reasons they are there is to reduce gain coming from headphone jacks (as opposed to the line out), and filter out low frequency. The second reason is the side effect of the first one.
Since I'm using a line out (highly recommended, for reasons see this post click here ), I decided to remove these components. It took about 45 minutes, and is well worth the effort. The sound quality is improved (not by a huge amount, but every bit helps!) and the volume is higher, which is a benefit when switching from, for example, aux input to CD, where before the volume difference was so great that when switching to CD, the volume was far too loud.
First, you need to remove the glove box door--instructions here:
click here
To access the aux input wiring harness, you need to remove a small (2" x 2") panel, which is located on a horizontal piece of the glove box liner, just below & in back of the aux input (see arrows in pic below--pic is before glove box door is removed):
There is a tab at the front of the panel--insert a screw driver and pry it open, then pull it down and out of the way (there's a cable attached to it--don't know what that's for). Then unscrew the washer that surrounds the aux input jack (needle nose pliers work best) and through the hole that the small panel exposed, pull the aux input through and down.
A few inches away from the aux input jack, you'll see a section of the harness that bulges, which contains the offending items--see pic (the section I removed is 5"):
Cut the wire on either side of the bulge, then remove the friction tape, and splice and solder the 3 wires (color coded--be sure to match). Wrap with electrical tape, test sound with iPod to ensure connections are correct, and reassemble.
Naturally, if you're about to have the aux input installed, it's a lot easier to perform this surgery before the harness is installed!
The sound quality is cleaner, with more bass response, and louder--all of which contribute to cleaner sound.
m_five is offline
post #2 of 5 Old 14th March 2006, 12:15 AM
MEnthusiast
Moderator Emeritus
MEnthusiast's Avatar
MEnthusiast is offline
post #3 of 5 Old 14th March 2006, 12:24 AM
frylord
frylord's Avatar
Also why the filter is there is to protect against "pops" or high impulses which occure when pulling the jack out of it's socket. If you're planning on a hardwired setup which you'll never remove then it's okay but if you're going to hook and unhook your devices alot then I suggest you leave the filter inplace.
'06 Nov M6 Mineral Silver Metallic/Merino Platin/Piano Black
frylord is offline
post #4 of 5 Old 14th March 2006, 12:27 AM
DrKevM5
DrKevM5's Avatar
DAMN I love this board!
Kevin
2001 M5 Carbon Black/Black SOLD
2005 M3 Carbon Black/Cinnamon SOLD
2008 M3 Sedan Jerez Black/Tan
2006 M5 Alpine White/Sepang/Walnut(SOLD)
2011 GMC Acadia Denali Carbon Black/Tan
2013 X3 Champagne Silver/Tan
2013 M5 Alpine White/Black Merino
"Amazing isn't it, that this is one of the ugliest and most annoying cars in the world but at the touch of a button it becomes one of the very best, it becomes.......an M5" - Jeremy Clarkson (e60 M5)
DrKevM5 is offline
post #5 of 5 Old 14th March 2006, 03:50 AM
jfenley
jfenley's Avatar
jfenley is offline
Definitive info on AUX. audio input retrofit kit. rost12 E39 M5 and E52 Z8 Discussion 15 10th March 2005 11:37 PM
"AUX" mode (lack-of) volume problem for I-PODs & DVD movies........ FAST 5 E39 M5 and E52 Z8 Discussion 8 16th September 2004 08:06 AM
E60 M5 Engine Sound rsteele E60 M5 and E61 M5 Touring Discussion 15 4th June 2004 03:25 PM
How to connect stereo aux input to stock head unit cjones E39 M5 and E52 Z8 Discussion 1 29th October 2002 10:14 PM
