how do I play music on phone? - BMW M5 Forum and M6 Forums
post #1 of 9 Old 11th July 2019, 08:59 PM Thread Starter
sunghyun7
sunghyun7's Avatar
my m5 is 2006 without aux port. I can connect BT but I think it's for phone only. It wouldn't play music on my phone.
is there a solution for me to play music on my phone on car speakers? thanks!
ESS VT2 + meth
sunghyun7 is offline
post #2 of 9 Old 11th July 2019, 09:33 PM
flacoramos
FM BT adapter would be the easiest solution. Nicest would be upgrade to CIC with combox. Intermediate would be add the aux port and run a cable to your phone, or install a BT adapter to the new aux port. Not much better than the FM adapter IMO.
flacoramos is offline
post #3 of 9 Old 11th July 2019, 09:40 PM
Slamfire
Slamfire's Avatar
E60's never had the ability to stream music via bluetooth from factory, just phone calls.
You can spend some money and retrofit a newer radio system like an android unit with bluetooth audio or retrofit CIC/NBT with combox and/or an aux jack.
You can just retrofit an aux jack. https://www.m5board.com/vbulletin/e6...input-e60.html
Other than that there are bluetooth radio transmitters. https://www.amazon.com/s?k=bluetooth...l_9d6nioyac4_e
07 6 speed E60 M5
12 6 speed E93 M3
Slamfire is offline
post #4 of 9 Old 12th July 2019, 02:28 PM
HM506
Or get the GROM BT and take out the factory BT and just replace it...works like a charm...
Sent from my SM-N950U1 using Tapatalk
HM506 is offline
post #5 of 9 Old 13th July 2019, 02:30 AM
wheeljack
with nbt he dont need combox , nbt have rear fakra for bt antena/usb etc
but nbt is great decision to make in e60. I have one after my ccc was broken, and after 2 years im sure its good decision
wheeljack is offline
post #6 of 9 Old 13th July 2019, 02:57 AM
flacoramos
Nbt sure seems nice. But remind us which settings are not accessible anymore with nbt? Is it hvac, m button settings and something else?
post #7 of 9 Old 13th July 2019, 03:28 AM
wheeljack
hvac work perfectly becouse emulator have script for it
if you need m button settings you can ask emulator seller for write script for it, its not a problem
one and only problem is a HUD - directly navi arrows on hud
post #8 of 9 Old 13th July 2019, 05:25 PM Thread Starter
sunghyun7
sunghyun7's Avatar
cool thanks guys! FM bt adapter sounds easy enough. probably pull the trigger on NBT eventually. not too comfortable with coding.
ESS VT2 + meth
post #9 of 9 Old 13th July 2019, 09:20 PM
wheeljack
Nbt you coding via enet cable with esys. Pretty easy with seller instruction
