SMG Communication Error in ISTA? - BMW M5 Forum and M6 Forums
post #1 of 8 Old 25th June 2019, 11:27 PM Thread Starter
Jdq5947
First post... been a stalker for almost a year since I purchased my M5
A little background before the real question. I recently got the red cog of death in my 06 with 74k miles on it. I had the car towed home and noticed a puddle of hydraulic oil under the car. I pulled everything apart and it turned out to be the slave cylinder but while i was in there i replaced the clutch, clutch position, etc.... Everything that has been recommended by this forum to replace when you have to pull the transmission anyway. Everything went very smooth mechanically, when I went to do the adaptation in ISTA is where I am having my issue. I did not bleed the slave cylinder before starting the adaptation so it failed, as expected but now I am getting this SMG communication error in ISTA. So now if i go into service functions and try to bleed off the system to do a fluid check it just sits there with the spinning hour glass and does not reduce the pressure. I then get an error in a pop up window that says "The communication with the control unit SMG has been disrupted. The ignition must be switched on or the PAD mode activated." The key has been in the on position the whole time, so it is not that. Has anyone had this error before? Did i somehow brick the SMG control module? Any help would be greatly appreciated
Also if anyone is curious the current fault codes are 4f66, 4f67, 5506
Jdq5947 is offline
post #2 of 8 Old 25th June 2019, 11:44 PM
flacoramos
flacoramos is offline
post #3 of 8 Old 26th June 2019, 01:52 AM Thread Starter
Jdq5947
Just tried INPA and got a pop up error "MOTOR aus", translated engine off.... Now i am really confused. Both pieces of software are pointing to the key being in the off position which is not the case.
I also have constant gongs with clutch adaptation active on the idrive. the gongs continue after the start button is pushed and the key is removed. It does eventually stop
Jdq5947 is offline
post #4 of 8 Old 26th June 2019, 12:56 PM
Ferris
Are you sure you the popup was an error or was it telling it you to shut the engine off? Inpa tells you when it wants the engine on or off during the process. I never used ISTA so I can't help you there.
What state are you in? Since summer is here I took a break from the SMG tuning project, rather spend time on water than on land, and as such I can lend you one of my spare SMG computers to try.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #5 of 8 Old 26th June 2019, 02:53 PM Thread Starter
Jdq5947
The more I thought about it last night you are probably correct, It was probably making sure the engine was not running. I have never used INPA for this so it made me jump to that conclusion. Once i click ok on the pop up window in INPA it starts the process but eventually faults out with an SMG communication error as well. I did not write down the complete error message but I will look when i get home. I am located in NY, finger lakes region specifically. I do not blame you for wanting to be on the water it has finally stopped raining here and the weather has warmed up enough to get out on the lakes.
Jdq5947 is offline
post #6 of 8 Old 26th June 2019, 03:02 PM
Ferris
Communication faults are risky issues, what's reporting it? Are other modules reporting errors? ie is the DME/DSC not able to communicate.
Ok well the offer to lend you a SMG TCU, feel free to pm and we'll work details. Let us know either way if you get it...
I drive up to Rochester to meet with a client every now and then, finger lakes are nice region.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #7 of 8 Old 27th June 2019, 03:37 AM Thread Starter
Jdq5947
Tried to PM you but I am not allowed to do to not having enough posts. I would like to take you up on the offer.
I am not sure what else this could be... any other thoughts?
Jdq5947 is offline
post #8 of 8 Old 27th June 2019, 01:05 PM
Ferris
write me at chris.laganga - gmail
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Panacea151
