Pushing my luck with 5mm spacers? - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By 4151zero
post #1 of 4 Unread 20th June 2019, 04:30 PM Thread Starter
V10Beamer
V10Beamer's Avatar
I was running stock tires on stock rims with stock suspension and 12 mm rear spacers. I just installed 295 35 19’s PSS and they was a lot of rubbing. I removed the spacers.No rubbing. I would like to push out the stance a bit but spacers under 10 mm don’t come with the rim for the wheel to rest on. My question is, 5 mm still leave enough of a rib for the wheel?
V10Beamer is offline
post #2 of 4 Unread 21st June 2019, 12:41 AM
4151zero
4151zero's Avatar
Yes they will have enough of the hub to rest on, however I would still use a stud conversion kit vs re using oem bolts.
2008 ///M5 Six Speed Space Grau
4151zero is offline
post #3 of 4 Unread 21st June 2019, 02:55 AM Thread Starter
V10Beamer
V10Beamer's Avatar
Even though the come with the longer bolts?
post #4 of 4 Unread 21st June 2019, 05:40 AM
4151zero
4151zero's Avatar
Not if the 5mm came with longer than stock bolts. They should be approx longer than spacers are thick
4151zero is offline
The Following 2 Users Say Thank You to 4151zero For This Useful Post:
V10Beamer (22nd June 2019)
