All the things you should NOT do when buying an E61 M5 - BMW M5 Forum and M6 Forums
 5Likes
post #1 of 22 Old 16th June 2019, 09:50 AM Thread Starter
Tourista
Hello friends,
Brand new member, first post. I will explain in more detail shortly, but for now I need your advice please.
You remember that scene in ‘Herbie goes bananas’ when the bad guy puts Irish coffee into Herbie’s fuel tank, and Herbie goes....bananas. That’s exactly what happened to my M5 touring yesterday. Completely bat %%^£ crazy. Wipers going, headlights on and off, door locking and unlocking, gauges lighting up like July 4th, ALL of the warning signs, etc.
A quick search on the net = check the spare wheel well (which is actually the electronics and battery well) for water.
As soon as I open the boot i can see condensation. I life the boot pan and I see water in the tools section. I open the left cubby and all the Electricals are covered in water. I lift the tool section of the boot and I see 3 inches of water. It’s all over all of the modules, the battery etc.
That explains it.
The question is: where is it coming from:
1. Blocked hose ends from the pan roof in the left and right cubbies
2. Rear headlight seal
3. Rear boot seal
None of these, I believe explain how the water has dispersed from the left hand cubby hole, throughout the entire boot area, UNLESS, when the hose ends from the pan roof become blocked due to the grommets at the bottom, the pipes leak not from the bottom, but from the top of the pipe, in the sun roof cassette somewhere.
As I type this, I think that must be the explanation.
So what I think i need to do, is to remove the grommet by pulling hard on the hose, then to clear out the pipes by remove the pipe entirely and blowing compressed air through them.
I know the headliner needs to be dropped for the second point. I haven’t searched for it yet, but i assume there will be a DIY on here somewhere.
Any tips?
A pleasure to meet you all.
Y
Tourista is offline
The Following User Says Thank You to Tourista For This Useful Post:
cncmastr (16th June 2019)
post #2 of 22 Old 16th June 2019, 09:56 AM
zarnd1
zarnd1's Avatar
Sorry to hear you are having problems. Any pictures of your touring? My Touring is Silverstone
Mine looks like it has had water in the back at some point in its life.
Keep us updated please.
Cheers
Alex
2007 M5 Touring
2012 Mini JCW GP2
2009 Caterham Supersport Race car
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
zarnd1 is online now
The Following 2 Users Say Thank You to zarnd1 For This Useful Post:
Tourista (17th June 2019)
post #3 of 22 Old 16th June 2019, 04:07 PM
Slamfire
Slamfire's Avatar
A relatively common issue with e61 wagons. At least for 535i in the states, never got the "estate" M5 here though I'd think the issues/solutions would be the same.
If memory serves, water can get in on the hatch via the antenna amplifier. A little bit of silicone sealant will fix it. Also can check sunroof drains, they get clogged super easy.
Edit because I'm a super good speller
07 6 speed E60 M5
12 6 speed E93 M3
Slamfire is offline
The Following 2 Users Say Thank You to Slamfire For This Useful Post:
post #4 of 22 Old 16th June 2019, 04:45 PM
J.R ///M5
J.R ///M5's Avatar
My vote goes to the drain hoses. All tourings with panorama roof are affected special equipment option "indoor pool". Those drain hoses should be cleaned every year. Dealer will do it in "vehicle check" which is scheduled once per year. Vehicle check costs only 54€. If you are diy'er add those in your maintenance plan.
You can rule out seals by going in the trunk and ask some one to spray water from outside to seams etc.
With tourings you should be always careful when using pressure washer. Trunk spoiler area is very sensitive to the water and it can ruin your diversity antenna amplifier which is located under the spoiler.
BMW E61 ///M5 -07
Ex. BMW E39 ///M5 -01
Current mods: Short shifter, Custom clutch stop, Alpha-N + Power tuning by Evolve, AP coilovers, HEL brake lines.
J.R ///M5 is offline
The Following 2 Users Say Thank You to J.R ///M5 For This Useful Post:
post #5 of 22 Old 17th June 2019, 12:53 AM Thread Starter
Tourista
These are the only pics I have so far:
Tourista is offline
post #6 of 22 Old 17th June 2019, 12:55 AM Thread Starter
Tourista
Tourista is offline
post #7 of 22 Old 17th June 2019, 01:04 AM Thread Starter
Tourista
Nightmare!
This is after I dried up inches of water in the battery compartment. The car could have caught fire! Disconnected battery and moved the polystyrene module holder to find more standing water. In the second photo you can see the little tray is full of water and whatever that module is that I removed, it's suffering from corrosion from water damage!
To make matters even worse, I closed the boot after I removed the battery (IDIOT) and so I had to use jump leads and another car to get power to the tailgate to open it.
I've cleaned the whole area. Now to find the culprit. Will start with the drain hoses. I had a go at pulling them out but they wouldn't budge. Will give it a but more muscle next time to try to get the end grommets to pop off.
Can anyone link me a DIY of how to drop the headliner to access the hoses?
Y
Tourista is offline
post #8 of 22 Old 17th June 2019, 06:52 AM
J.R ///M5
J.R ///M5's Avatar
Good looking car! Tourings are something special. Good luck with the repairs!
Here is a link for headliner removal: https://www.newtis.info/tisv2/a/en/e...lining/DmKI8IR
Here's a link for checking water drain hoses: https://www.newtis.info/tisv2/a/en/e...-roof/IOAWU1i5
BMW E61 ///M5 -07
The Following User Says Thank You to J.R ///M5 For This Useful Post:
post #9 of 22 Old 18th June 2019, 07:49 PM Thread Starter
Tourista
The culprit!!!
Put the car back together, the battery is back in, the electrics mostly dry and connected back up. The car started!
Still throwing out lots of errors. Drove it to the garage.
The issue is now that the shop are making noises that this is going to cost moneeeeeeey to replace all the modules.
I'm scared.
Tourista is offline
post #10 of 22 Old 18th June 2019, 07:52 PM Thread Starter
Tourista
I'll also add that the garage won't allow me to purchase second hand modules. It's all gotta be straight from BMW. Update to follow tomorrow.
Tourista is offline
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
