A Long list of codes - BMW M5 Forum and M6 Forums
post #1 of 1 Old 18th May 2019, 05:16 PM Thread Starter
Tawitt
Hello all, I’m hoping for some input as to why I may have all these codes. I’ve been dealing with this issue for about a month after replacing the slave cylinder. The issue I’m having is the car is occasionally misfiring and going in to limp mode not letting RPMs go over 4500. When this happens about 80 percent of the time it can be cured by shutting the vehicle off, then restarting. I’ve replaced all the coils and plugs which made it run incredible for three days. Also when letting the car warm up the idle fluctuates between 500-2000 for about a min before sitting steady at about 800. Sometimes this will put it in limp mode, but not always. Here are the codes I’m getting with a Snap On Solus-
2726 Lambda Sensor Plausibility CAT Bnk1
2727 ^^ Bank 2
2B3A B C D E Combistion Misfire w/ cutout Cylinder 6-10
2B41 Several Cylinders Misfire
2B57/2796 Safety Concept Manager Action
2B47 48 49 4A 4B Combustion Misfire w/ Emissions Deterioration Cyl 6-10
275D Lambda Control Limit Postion Bank 1
275E ^^ Bank 2
278A Fuel System Diagnostic Bank 1
272A VANOS Control inlet Bank 1
271C ^^ Bank 2
2B63 Idle Control Monitoring
2B36 37 38 39 Combustion Misfire w/Cutout cyl 2-5
2B42 Combustion Misfire w/Emissions Deterioration cyl 1
I should also mention I’ve had an Increased Emissions Message popping up since I bought the car in Nov., but it’s never effected the car. This is on a 06 with 70k. Any input would be greatly appreciated. Thank You!
Tawitt is offline
Odd correlation between TB actuators and cat codes? robbins549 E60 M5 and E61 M5 Touring Discussion 0 22nd August 2016 07:50 AM
Add Another M3 to Our Long List - F80 on HRE P101's by Wheels Boutique thewb Tires, Wheels, Brakes & Suspension Forum 0 16th February 2016 06:13 PM
Laundry list of codes and Engine Failsafe Prog mode KWP E39 M5 and E52 Z8 Discussion 4 22nd February 2015 04:39 PM
Vanos codes and rough idle after new board! manualshifter E39 M5 and E52 Z8 Discussion 41 12th January 2015 06:12 AM
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 90 2nd September 2011 09:49 AM
