Picked up an M5, broke on the way home - LFA - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 17 Old 14th May 2019, 03:43 PM Thread Starter
AlexDoran
Hi all,
Last Saturday i picked up my E60 M5, 2007 LCI with 65k on the clock. On paper the car is perfect, had alot of common faults already fixed, and has had a warranty most of its life so it has wanted for nothing. The drive home was about an hour, however about half way home i eventually got the car on the motorway and let it wind on in 4th gear P500S to above 7k RPM. After returning to normality, about 20 - 30 seconds later the car went into limp mode with an engine fault. Very rough running, severe misfiring etc. Drove a few miles further to the next exit, pulled up the trafffic lights with a LOT of smoke and very strong smell of fuel. I pulled over and switched it off, went to restart it and it failed to start - after a few turns it simply locked (hydro locked im sure). Got the car trailered back to the warehouse where i work and plugged my code reader in. Many many cylinder misfire with cut-off codes, lambda reading codes, fuel pressure error. Oil cap stinks of fuel, car swallowed roughly a quarter of a tank in the few miles it was driven.
I contacted the dealer and eventually took the car back last night to his independent specialist who has been looking after the car for the last 5 years.
I have not heard anything back yet, assuming the worst, i am looking for some advice on aspects of the engine i want checking before taking the car back. I would really appreciate some advice.
Alex
AlexDoran is online now
post #2 of 17 Old 14th May 2019, 03:55 PM
HM506
HM506 is online now
post #3 of 17 Old 14th May 2019, 04:22 PM
flacoramos
Sounds like an injector stuck open. Hope you didn't bend a con rod.
Also, 2007 is not LCI.
flacoramos is offline
post #4 of 17 Old 14th May 2019, 04:42 PM Thread Starter
AlexDoran
Originally Posted by HM506 View Post
Were the rod bearing ever done?
Sent from my SM-N950U1 using Tapatalk
It's pretty much the only thing not done along with the usual vanos bits.
Yes i had assumed this too, assuming no bent rods, could there be other damage even if the engine restarts and appears to be ok?
It is LCI, at least the interior is, i assumed one of the first.
https://www.tlrautos.co.uk/used-bmw-...dorset-2081436
Alex
post #5 of 17 Old 14th May 2019, 05:20 PM
flacoramos
My bad, forgot about europe where LCI may have rolled out earlier. Headlamps and interior are certainly LCI, but front bumper is missing the side reflectors. Then again maybe europe LCI's never had bumper reflectors.
As for the hydrolocking... assuming it's a fuel injector it may be ok. I'd ask for compression and leak down testing and go from there.
The Following User Says Thank You to flacoramos For This Useful Post:
AlexDoran (14th May 2019)
post #6 of 17 Old 17th May 2019, 06:14 AM
ACG
ACG's Avatar
Sounds like stuck open injector, hopefully no bent rods or scoring of the cylinder walls.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression 5.1L Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights / Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions / CF Trunk Spoiler
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, Pearl white
ACG is offline
post #7 of 17 Old 17th May 2019, 11:07 AM Thread Starter
AlexDoran
I hope so too man, spoke to the dealer yesterday who said the indy had ordered some parts for it. Assuming bent rods & scored bores, can these be picked up in compression tests? (Mainly the scored bore).
Not sure what my move should be if the engine is now in bad shape:
- Ask for my money back?
- Push for a replacement / rebuild?
Alex
post #8 of 17 Old 17th May 2019, 12:23 PM
Craze
I want to know whats wrong first
But likely id want my money back
Craze is online now
post #9 of 17 Old 17th May 2019, 05:30 PM Thread Starter
AlexDoran
Had a call earlier, apparently Injector 8 had failed, compression test came back with all cylinders ~8bar.
Going to replace all 10 injectors and swap out the oil.
Is a compression test really much use here? What about leakdown for bore scoring? How do you identify bent rods? Engine tear down? Im learning here still so sorry for the stupid questions.
Thanks for the help.
Alex
post #10 of 17 Old 17th May 2019, 06:30 PM
Craze
Boroscope to check bores
Bent rods engine will be noisy
Craze is online now
help pls .. limp home mode? psiggy E39 M5 and E52 Z8 Discussion 7 19th April 2008 09:48 PM
My New Beast is Home! 2strokecoldsmoke Owners Gallery 5 1st April 2008 08:35 PM
Picked up our M5 today!! 993 4S E39 M5 and E52 Z8 Discussion 12 17th February 2002 03:34 PM
1 week, 2,650 miles later...Home sweet home.. beewang E39 M5 and E52 Z8 Discussion 11 5th November 2001 09:29 AM
Home on the Range JFB E39 M5 and E52 Z8 Discussion 39 10th September 2001 05:53 AM
