Picked up an M5, broke on the way home - LFA - Page 2 - BMW M5 Forum and M6 Forums
 1Likes
post #11 of 17 Old 17th May 2019, 06:35 PM
flacoramos
One could use a caliper to ensure the piston is still extending all the way up (i.e. no bent rod). Injector failure is likely due to the gas filter letting crap through / disintegrating. Must change the filter.
flacoramos is offline
post #12 of 17 Old 17th May 2019, 07:09 PM Thread Starter
AlexDoran
Ok thanks guys, i will push to get those done. Is a bent rod likely from hydrolocking under the start motors power alone? It locked after 3 or 4 cranks (i would just before it was about to fire).
AlexDoran is offline
post #13 of 17 Old 17th May 2019, 08:47 PM
ACG
ACG's Avatar
It depends on the state of the engine when it hydrolocks, it could be due to a bent rod. To check scoring you would need a boroscope to confirm any damage.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression 5.1L Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights / Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions / CF Trunk Spoiler
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, Pearl white
ACG is offline
post #14 of 17 Old 26th May 2019, 01:51 PM Thread Starter
AlexDoran
Got the car back yesterday, 10 new injectors and Fresh Oil / filter, seems to be driving great. No audible knocking and no smoke currently. Its bank holiday here in the UK so im going to get it into my indy Tuesday and see what he says.
Alex
The Following User Says Thank You to AlexDoran For This Useful Post:
post #15 of 17 Old 26th May 2019, 03:50 PM
flacoramos
post #16 of 17 Old 28th May 2019, 12:49 AM
TexaZ3
TexaZ3's Avatar
Originally Posted by flacoramos View Post
Good, now get the gas filter changed or injectors will fail again.
Petrol filter.
E36 1999 M3 Coupe Dakar Yellow/Black Vaders
E36 2000 M Coupe Cosmos Black/Black Leather, Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein.
E39 2000 M5 Imola/Black Heritage
E46 2005 M3 Coupe ZCP Carbon Black/Black
E63 2006 M6 Coupe Indianapolis Red/Black/Madeira, Style 343
TexaZ3 is offline
post #17 of 17 Old 28th May 2019, 04:16 PM Thread Starter
AlexDoran
Ok, maybe i will just do that myself I am not sure yet. One thing i have noticed is that at very low RPM's (1k - 1.75k) the engine seems to be a little rough (minor misfiring), maybe needs some new plugs? I have INPA so was going to see if i could inspect the combustion quality using it??? Any guidance would be greatly appreciated.
Alex
help pls .. limp home mode? psiggy E39 M5 and E52 Z8 Discussion 7 19th April 2008 09:48 PM
My New Beast is Home! 2strokecoldsmoke Owners Gallery 5 1st April 2008 08:35 PM
Picked up our M5 today!! 993 4S E39 M5 and E52 Z8 Discussion 12 17th February 2002 03:34 PM
1 week, 2,650 miles later...Home sweet home.. beewang E39 M5 and E52 Z8 Discussion 11 5th November 2001 09:29 AM
Home on the Range JFB E39 M5 and E52 Z8 Discussion 39 10th September 2001 05:53 AM
