Looking to buy an E61 M5 2008 - Page 2 - BMW M5 Forum and M6 Forums
 9Likes
post #11 of 24 Old 14th May 2019, 07:00 AM
J.R ///M5
J.R ///M5's Avatar
Congratulations for your new car! When it's time for rod bearings you might want to consider to get after market ones with bigger clearance. Also there is ton of info on this forum about the other maintenance item's which you might want to tackle same time with the bearings. Internal vanos oil line, oil pump tensioners, motor mounts etc.
There is a good rebuild service for throttle actuators in the UK, if your present ones decides to break. I have spare set of actuators which were refurbed by http://www.rebuild.org.uk you never know when you need them
BMW E61 ///M5 -07
Ex. BMW E39 ///M5 -01
Current mods: Short shifter, Custom clutch stop, Alpha-N + Power tuning by Evolve, AP coilovers, HEL brake lines.
J.R ///M5 is online now
post #12 of 24 Old 14th May 2019, 09:41 PM Thread Starter
JackbauerM5
JackbauerM5's Avatar
Shes booked in tues/wed next week with a specialist for the big service, brakes and rear suspension arms. Also, I hope to discuss rod bearings and other such things I can do as a preventative measure, as well as updates and maybe some coding! I'll keep you all posted!
JackbauerM5 is offline
post #13 of 24 Old 21st May 2019, 08:39 PM Thread Starter
JackbauerM5
A wee update:
So dropped the beast off at my new Indy in Glasgow-
Rear brake pads new- discs are done! Why would the previous Indy not replace the discs?? New rear brakes ordered!!
Rear suspension arms fine for now.
Front bushes being changed to polymer ones.
Front brakes ok 👍
Discovered that the front right under tray in front of the wheel has had a hole cut in it- Indy suspects a pi$$ed off mechanic who was having trouble accessing the oil filter is the guilty party- whole new front undertray/wheel arch tray requires- ordered!
Doesn’t look like the transmission fluid has been changed- ever!! Full inspection II/major service being carried out!!
Rod bearings/shells- long discussion, another customer who’s car was running perfect with perfect history decided to do the preventative measure and replace- just in time, some very worn shells!! Saw the pictures- not pretty!! New parts ordered and to be fitted!
I’ll get the beast back next week, meanwhile I have a mini as a courtesy car 😭 it’s not the same, it really is not!!
I’ll update on progress and any other info as I get it 😃
post #14 of 24 Old 22nd May 2019, 06:50 AM
J.R ///M5
J.R ///M5's Avatar
Seems like the M got a very good new homeWhich bearing shells you ordered? I suggest that you replace the internal vanos pressure hose while the rod bearings are changed.
BMW E61 ///M5 -07
post #15 of 24 Old 22nd May 2019, 08:26 PM Thread Starter
JackbauerM5
Originally Posted by J.R ///M5 View Post
Seems like the M got a very good new home[IMG class=inlineimg]/vbulletin/images/M5Board_vbtoucan/smilies/tango_face_smile.png[/IMG]Which bearing shells you ordered? I suggest that you replace the internal vanos pressure hose while the rod bearings are changed.
I’ll find out tomorrow which ones my Indy was talking about- forgotten the name.
Is the Vanos pressure hose something that needs replaced?
post #16 of 24 Old 22nd May 2019, 09:11 PM
J.R ///M5
J.R ///M5's Avatar
There's some cases that the internal vanos high pressure line is ruptured. It's not a big cost to change the line when the oil pan is off. Mine was changed also when my rod bearings (BE bearings) was changed last year. Also oil pump tensioners and piston oil squirters was changed.
BMW E61 ///M5 -07
post #17 of 24 Old 30th May 2019, 03:45 PM Thread Starter
JackbauerM5
post #18 of 24 Old 3rd June 2019, 05:05 PM
J.R ///M5
J.R ///M5's Avatar
I have those bearings. You can't go wrong with BE. Ordered mine from https://www.ca-int.co.uk/home.php
BMW E61 ///M5 -07
post #19 of 24 Old 17th June 2019, 04:32 PM Thread Starter
JackbauerM5
Right! Finally got my car back!
Bearings replaced
Rear brakes replaced
Front suspension bushes (BMW)
Full service- trans/gearbox/engine oil filters etc
Running sweet!!
I believe these are the bearings fitted with ARP bolts
https://www.hackengineering.co.uk/pr...aring-set-s85/
Removes bearings in pic- well worn
post #20 of 24 Old 17th June 2019, 04:38 PM Thread Starter
JackbauerM5
Video: Audi RS5 (double clutch 450 HP) vs BMW M6 Coupe, both stock Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 48 27th November 2011 05:41 AM
New 2008 E60 led tailights OEM BMW part - Group buy Done Alex.br M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 136 3rd October 2011 05:50 AM
BMW M sales are up 50% for 2008 vs previous year + M model specific sales for the year Gustav E39 M5 and E52 Z8 Discussion 4 3rd February 2009 11:59 PM
BMW M sales are up 50% for 2008 vs previous year + M model specific sales for the year Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 2nd February 2009 03:56 PM
New MY 2008 facelift E60 led tailights OEM BMW part - Group buy Alex.br M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 7 24th April 2007 03:58 AM
