Track tires?? - BMW M5 Forum and M6 Forums
 16Likes
post #1 of 44 Old 9th May 2019, 08:03 AM Thread Starter
simonnim
simonnim's Avatar
Track tires??
I've done tons of searching with no conclusive answer. I've reached a few conclusions.
- Run 245/40 front and 275/35 rears on stock wheels(more options)
- Run 255/40 front and 285/35 rears on stock wheels(fewer options)
- Buy a set of 18's, Apex arc8
Preferably I want to run my stock wheels...I know they aren't forged but I don't plan on tracking the car a lot.
Can someone help me with some options?
Running a smaller width will give me a stiffer sidewall. Can I run 245/35? Or 255/35?
I can't find anything...
2007 E60 M5 - Indianapolis Red
- Bearings changed at 69,500 with WPC coated 702/703
- RPI scoops & BMC filters
- Charcoal filter delete
- Custom X-pipe
- Resonator Delete
- G-Power section 3
- Gloss black kidney and fender grills
- Euro SMG tune
- ECS stainless steel brake lines
- Castrol SRF brake fluid
simonnim is offline
post #2 of 44 Old 9th May 2019, 09:45 AM
Hasan Shaikh
Hasan Shaikh's Avatar
Hasan Shaikh is offline
post #3 of 44 Old 9th May 2019, 09:47 AM
Hasan Shaikh
Yes
post #4 of 44 Old 9th May 2019, 05:20 PM Thread Starter
simonnim
simonnim's Avatar
I was hoping you'd respond Hasan. I know you've done a bunch of testing on the stock set up. Are those the tires you'd recommend?
- Custom X-pipe
- Resonator Delete
- G-Power section 3
- Euro SMG tune
simonnim is offline
post #5 of 44 Old 10th May 2019, 07:20 PM Thread Starter
simonnim
simonnim's Avatar
Will 255/35/19 fronts and 285/35/19 rears be bad to run? Will it mess with the speedo and or throw the traction control haywire? I'm looking at re-71r's in that size.
- Custom X-pipe
- Resonator Delete
- G-Power section 3
- Euro SMG tune
simonnim is offline
post #6 of 44 Old 10th May 2019, 08:30 PM
flacoramos
FYI I ran 275/35/18 on apex arc8's all around. Fronts will need 15mm spacers. Oh and I had BFG R1s which run WIDE, def much wider than a street 275/35/18. I think most R tires are like this tho.
flacoramos is offline
post #7 of 44 Old 10th May 2019, 08:36 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
No. You shouldn’t have a problem. You can always turn off your TC, too. From memory, the high banking at Autoclub did mess with my e39 TC, but never with my e60.
Ive never concerned myself about any speedo error — especially at the track.
At the track, I’m watching my tach and temps, not my speedo.
Have fun!
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =162,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; MCS 2WNR motorsport coilover, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Nuke Performance fuel rail and pressure regulator, Carbon Fiber CSL intake; Lifeline Zero 360 FIA 3.0kg Novec fire suppression; Cool Shirt Pro Air/Water system; Euro RestoMod track car: caged, 6 point Schroth FIA harness, FIA Sparco Ergo & Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x9 BBS Style 42 w/Michelin Cup 2; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
Not-spec e30 racercar!!! Fully caged for wheel 2 wheel racing
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
post #8 of 44 Old 11th May 2019, 06:44 AM Thread Starter
simonnim
simonnim's Avatar
Have fun!
Thanks! I don't think I'm quite ready to take TC off yet. I've decided to go with some Federal RS-RR's in 245/40 and 275/35. Not a bad price $400 out the door. I heard they are ridiculously loud though, but won't be an issue since I don't daily the beast. I've rode on these federals on some other track mobiles, but nothing this high powered. Hopefully, they work out.
- Custom X-pipe
- Resonator Delete
- G-Power section 3
- Euro SMG tune
simonnim is offline
post #9 of 44 Old 12th May 2019, 11:30 PM Thread Starter
simonnim
simonnim's Avatar
Testing to see if tires post.
- Custom X-pipe
- Resonator Delete
- G-Power section 3
- Euro SMG tune
simonnim is offline
post #10 of 44 Old 13th May 2019, 05:44 AM
Fiftytwoeighty
Link not working
~Woody
~I FRACKING!
~Viva La Wolfpack!
the Official 2008 Winter Tire Thread .... [email protected] E39 M5 and E52 Z8 Discussion 30 17th February 2009 11:45 PM
Track time opportunity with Northwoods Shelby club at Autobahn Country Club (Midwest area) Wi_KeD_M5 Track, Racing and Drivers Education 2 12th October 2008 02:44 AM
VIR Track Report -- Pilot Sport Cups (and new personal lap record) MRichmond E60 M5 and E61 M5 Touring Discussion 40 23rd July 2007 06:11 PM
Track tires vs burn my streets? DrDave E39 M5 and E52 Z8 Discussion 22 21st February 2006 11:50 PM
Track tires for M5- help? DrDave E39 M5 and E52 Z8 Discussion 9 12th February 2006 02:08 PM
