Track tires?? - Page 4 - BMW M5 Forum and M6 Forums
 16Likes
post #31 of 44 Old 18th May 2019, 07:08 AM Thread Starter
simonnim
simonnim's Avatar
I think next steps if I enjoy how she goes around the track is, monoballs, and pads/rotors.
2007 E60 M5 - Indianapolis Red
- Bearings changed at 69,500 with WPC coated 702/703
- RPI scoops & BMC filters
- Charcoal filter delete
- Custom X-pipe
- Resonator Delete
- G-Power section 3
- Gloss black kidney and fender grills
- Euro SMG tune
- ECS stainless steel brake lines
- Castrol SRF brake fluid
simonnim is offline
post #32 of 44 Old 19th May 2019, 12:15 AM Thread Starter
simonnim
simonnim's Avatar
Ugh..So I got the brake fluid, but I noticed the date on the back, 10.06.08....is it me or is this extremely old stock..
- Custom X-pipe
- Resonator Delete
- G-Power section 3
- Euro SMG tune
simonnim is offline
post #33 of 44 Old 19th May 2019, 08:39 PM Thread Starter
simonnim
simonnim's Avatar
Originally Posted by flacoramos View Post
Forgot to add to push the caliper pistons all the way in before you drain the old fluid out. Otherwise there's a lot of fluid held within the calipers, i.e. there'd be no point in doing this 'thorough' method.
Do I need to flush the ABS with INPA? Is it okay if I don't?
- Custom X-pipe
- Resonator Delete
- G-Power section 3
- Euro SMG tune
simonnim is offline
post #34 of 44 Old 20th May 2019, 04:11 AM
flacoramos
If you're doing a regular flush then INPA is not a must. If you do as I said (pressurize and bleed until air comes out) then INPA is a MUST.
flacoramos is offline
post #35 of 44 Old 1st June 2019, 01:39 AM Thread Starter
simonnim
simonnim's Avatar
Alright,
Just finished the track day. My thoughts were, the tires were very sticky, it was a warm day. 92 degrees by my 3rd session. The issues I began noticing, the abs was starting to come on most of the turns, the stock brake pad fade was hurting my confidence. And sway bars need to change if I am to push it harder, it felt wobbly on the turns. It could be my bushings, but they looked in good shape last inspection.
Next upgrades will definitely need brakes and sway and camber the front, the outside of my tire after my first session was noticibly hotter than my inside, checked with a temp needle.
I'll look into monoballs after another day. Nonetheless, I was surprised at how agile a 4100 pound fully extended leather etc. handles, then takes me home in full comfort.
- Custom X-pipe
- Resonator Delete
- G-Power section 3
- Euro SMG tune
simonnim is offline
post #36 of 44 Old 1st June 2019, 02:25 AM
Fiftytwoeighty
Fiftytwoeighty's Avatar
Alright,
Lol! Spot-on for stock configuration! Hauling down 4100#s repeatedly from 140mph to 60mph will cook our stock pads.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =158,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; CKS coils w/swift springs, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Euro RestoMod track car: caged, 6 point FIA harness, FIA Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x8 BBS RK w/Dunlop StarSpec II; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
post #37 of 44 Old 1st June 2019, 05:34 AM
flacoramos
Alright,
To recap, what tires did you end up using? And post a pic of the fronts outer shoulders.
You mean traction control during turns? Or abs while braking? Also note pad fade can be easily fixed with race pads. Pedal fade means better fluid is needed (or proper bleeding, met a guy at the track who said he was boiling srf, when asked how much fluid had been used for bleeding he said half a bottle = fail).
If you meant traction control then competition mdm will allow most conditions but drifting at the track. Highly recommended. Or if you're confident enough then dsc off.
post #38 of 44 Old 1st June 2019, 06:02 AM Thread Starter
simonnim
simonnim's Avatar
I went with federal rs-rr 245/40 front 275/35 rears. I'll take a shot of the shoulders tomorrow. I used two liters during the bleed and did the Piston compression and full bleed with inpa. It was stopping further and further but pedal feel was still firm. I'm sorry! I mean traction control! I'm not confident enough as this was the first time taking the car on the track. I'll go for it next time though.
- Custom X-pipe
- Resonator Delete
- G-Power section 3
- Euro SMG tune
simonnim is offline
post #39 of 44 Old 1st June 2019, 07:49 AM
Fiftytwoeighty
Track tires??
The links in your pictures are broken, not showing.
After a day at Buttonwillow, a good setup tire should look like this:
~Woody
~I FRACKING!
~Viva La Wolfpack!
post #40 of 44 Old 1st June 2019, 02:23 PM
flacoramos
the Official 2008 Winter Tire Thread .... [email protected] E39 M5 and E52 Z8 Discussion 30 17th February 2009 11:45 PM
Track time opportunity with Northwoods Shelby club at Autobahn Country Club (Midwest area) Wi_KeD_M5 Track, Racing and Drivers Education 2 12th October 2008 02:44 AM
VIR Track Report -- Pilot Sport Cups (and new personal lap record) MRichmond E60 M5 and E61 M5 Touring Discussion 40 23rd July 2007 06:11 PM
Track tires vs burn my streets? DrDave E39 M5 and E52 Z8 Discussion 22 21st February 2006 11:50 PM
Track tires for M5- help? DrDave E39 M5 and E52 Z8 Discussion 9 12th February 2006 02:08 PM
