2008 M5, flywheel clutch replacement - BMW M5 Forum and M6 Forums
 3Likes
post #1 of 14 Old 9th May 2019, 03:06 AM Thread Starter
sunilshivaram
The flywheel and clutch was replaced and car won't start up now.
It keeps cranking but doesn't fire.
What are the possible issues we have here ?
The BMW Foxwell scanner shows no error codes stored in the DME module.
The Master Technician claims the flywheel isn't OEM and we should re-do
the work using the old flywheel. He thinks the flywheel position sensor isn't
picking up the signal from the new flywheel.
is there anything else that we should look into ?
Thanks!
sunilshivaram is offline
post #2 of 14 Old 9th May 2019, 03:47 AM
flacoramos
Sounds like the flywheel was incorrectly installed. Someone else posted about this a while ago. Bolt pattern is supposed to only let you install it in the correct orientation but apparently one can force it in some other way.
flacoramos is offline
post #3 of 14 Old 9th May 2019, 04:28 AM Thread Starter
sunilshivaram
Thanks for the quick reply.
This is the quote i have from that other thread: "There are nine different ways to mount the FW, but only 1 is right".
Any clues what we should look for ? Where can i find the correct orientation.
post #4 of 14 Old 9th May 2019, 06:23 AM
chadjones99
chadjones99 is offline
post #5 of 14 Old 9th May 2019, 12:49 PM
Ferris
Any shop that has ever done a BMW flywheel before should know. That said if you did it yourself, there is dowel on the crank on one of the bolt holes. On the front of the flyhwheel in hte center there is a marking that looks like ^-^ that marking lines up with the dowel pin. Now you reallly have to beat on it to get it to fit wrong, and if you do you might crush the dowel. IT's replaceable if you have to.
What aftermarket flywheel did you get?
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #6 of 14 Old 9th May 2019, 03:34 PM Thread Starter
sunilshivaram
its LuK, came with the Clutch Kit.
post #7 of 14 Old 9th May 2019, 03:42 PM
Ferris
LUK is OEM minus the BMW logo
I assure you it works and it has the alignment stamping on it.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #8 of 14 Old 9th May 2019, 06:54 PM Thread Starter
sunilshivaram
Thank you, this is very helpful. We will be taking the clutch and flywheel out tomorrow , i will give these details to the mechanic. He hasn't done a BMW SMG before, but they are bending over backwards to help me out.
post #9 of 14 Old 9th May 2019, 06:59 PM
Ferris
Gonna give you a hint here then too...
Since he hasn't done an smg before, I assume he doesn't have the "special" clutch tool. So when takes it off make sure it doesn't fall apart esp the first clutch disk. The two plates and two disks are balanced with each other's counter part so try to prevent it from separating. If it does you'll find the mating paint marks and you can figure it out, but better to prevent it from happening. Second if you have the ship spring still, before losing the pressure plate stick the spring back in. It makes putting it back on easier.
Also make sure the flywheel marks and the clutch marks are 180 degrees apart.
I have an old flywheel laying around I can grab a pic of the marks.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #10 of 14 Old 9th May 2019, 07:13 PM Thread Starter
sunilshivaram
Replacing the E39 M5 Clutch and Flywheel with Original Equipment OldRanger M5 E39 and E60 tips & tricks 37 19th December 2014 02:59 AM
Clutch & Flywheel Replacement for The Red Baroness RedBaroness E39 M5 and E52 Z8 Discussion 31 3rd December 2011 06:38 PM
UUC * Invest in this for your E39: mega flywheel deals AND Corsa exhaust combo package. Rob Levinson M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 0 16th September 2008 03:59 PM
FAQ regarding UUC & Spec clutch kits marcvip E39 M5 and E52 Z8 Discussion 119 4th April 2005 10:12 PM
