2008 M5, flywheel clutch replacement - Page 2 - BMW M5 Forum and M6 Forums
 3Likes
post #11 of 14 Old 9th May 2019, 07:16 PM Thread Starter
sunilshivaram
Originally Posted by Ferris View Post
Also make sure the flywheel marks and the clutch marks are 180 degrees apart.
Whats the technical reason for this ? The markings are hand made, and appear to indicate the points where the clutch kit and flywheel are balanced from the company.
However, if we are re-using the flywheel, it doesn't make any sense to try to align them with 180 offset.
sunilshivaram is offline
post #12 of 14 Old 9th May 2019, 10:30 PM
flacoramos
As you suggest it's for balancing. This sheet of instructions comes with the clutch, let's see if it works:
https://webcat.zf.com/nc2_getfile.as...14bcdc3a80f00c
Edit: Looks like it doesn't... you can get it by going to the zf webcat site https://webcat.zf.com/?SPR=4 then search for the clutch kit for the e60 m5, open the clutch kit PN then look under assembly information.
flacoramos is offline
post #13 of 14 Old 13th May 2019, 08:36 PM Thread Starter
sunilshivaram
Any shop that has ever done a BMW flywheel before should know. That said if you did it yourself, there is dowel on the crank on one of the bolt holes. On the front of the flyhwheel in hte center there is a marking that looks like ^-^ that marking lines up with the dowel pin. Now you reallly have to beat on it to get it to fit wrong, and if you do you might crush the dowel. IT's replaceable if you have to.
What aftermarket flywheel did you get?
the flywheel has clear markings on it ^-^, Roger That.
I think the mechanic just placed the flywheel on the crank, aligned the bolts, and went to town with the impact wrench, that's how they do it lol. There were shiny scrape marks on the dowel when he took the flywheel off. He doesn't clearly remember how it was aligned. I asked him to work on it slowly, hand torque it, and work on it in his free time , no need to rush with power tools on the flywheel and clutch.
--Fingers Crossed--
post #14 of 14 Old 14th May 2019, 09:11 PM Thread Starter
sunilshivaram
Car is up and running ! It was the flywheel misaligned with the crank position. THANK YOU ALL SOOO MUCH !! /heart/
Replacing the E39 M5 Clutch and Flywheel with Original Equipment OldRanger M5 E39 and E60 tips & tricks 37 19th December 2014 02:59 AM
Clutch & Flywheel Replacement for The Red Baroness RedBaroness E39 M5 and E52 Z8 Discussion 31 3rd December 2011 06:38 PM
UUC * Invest in this for your E39: mega flywheel deals AND Corsa exhaust combo package. Rob Levinson M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 0 16th September 2008 03:59 PM
FAQ regarding UUC & Spec clutch kits marcvip E39 M5 and E52 Z8 Discussion 119 4th April 2005 10:12 PM
