Chasing the gremlin - BMW M5 Forum and M6 Forums
post #1 of 14 Old 3rd May 2019, 05:40 PM Thread Starter
Truenorth
Looking for any help here guys, !! It’s a 2007.
Every other day when the car is started it will cycle through ALL dash warning messages starting with the yellow triangle. In addition the IDRIVE screen will stay blank. Eventually the Idrive screen returns and the car will drive ok, albeit without power steering and DSC etc etc with warning lights all over the dash. After advice from this board I HAVE replaced the alternator and voltage regulator and battery. Still having the issue. Too many codes to list when this happens. And after clearing codes this won’t happen for another day or two. I’m at a loss?? Perhaps a bad ground ?? Any advice would be much appreciated.
Truenorth is offline
post #2 of 14 Old 3rd May 2019, 07:22 PM
Ferris
Originally Posted by Truenorth View Post
Looking for any help here guys, !! Itís a 2007.
Every other day when the car is started it will cycle through ALL dash warning messages starting with the yellow triangle. In addition the IDRIVE screen will stay blank. Eventually the Idrive screen returns and the car will drive ok, albeit without power steering and DSC etc etc with warning lights all over the dash. After advice from this board I HAVE replaced the alternator and voltage regulator and battery. Still having the issue. Too many codes to list when this happens. And after clearing codes this wonít happen for another day or two. Iím at a loss?? Perhaps a bad ground ?? Any advice would be much appreciated.
Yes I'd check the engine ground strapping.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #3 of 14 Old 4th May 2019, 04:49 PM
Ltanderso
Did you code the battery to the car? If so, have you tried it a second time? Check the connections at the battery too. Make sure they’re tight and not corroded.
Ltanderso is offline
post #4 of 14 Old 4th May 2019, 11:51 PM Thread Starter
Truenorth
Thanks LT I’m pulling my hair out, perhaps a bad battery, maybe not coded correctly. Very intermittent but driving me crazy.
post #5 of 14 Old 5th May 2019, 04:39 PM
pmalik
Bad PT-Can connection somewhere would do this also - do you have the seats with moving bolsters? Post a screen shot of rheingold to see what modules are coding out.
pmalik is offline
post #6 of 14 Old 5th May 2019, 06:17 PM Thread Starter
Truenorth
I do have the seats with the moving bolsters, I’ll get the guys to hook it up to that program on Monday and see if it’s coding out. Is there anything in particular I’m looking for? I did leave all the codes and didn’t clear them from the last Christmas tree event.
post #7 of 14 Old 6th May 2019, 12:07 AM
pmalik
PT-can is a ring network, so if there's a loose contact in either one of the seat connectors, all the other modules will complain that they're missing PT-can traffic like vehicle speed, steering angle etc. Things like DSC/ABS, seats etc will error out without that data.
pmalik is offline
post #8 of 14 Old 6th May 2019, 02:50 AM Thread Starter
Truenorth
I’ve brushed up on my PT-can, so will Rhinehold or however you spell it be able to see what module is not coughing up the info to make everyone else happy ? Either way I’ll report back and really appreciate the help.
post #9 of 14 Old 6th May 2019, 07:50 PM
pmalik
Iíve brushed up on my PT-can, so will Rhinehold or however you spell it be able to see what module is not coughing up the info to make everyone else happy ? Either way Iíll report back and really appreciate the help.
Yeah, there's a fun little chart view that shows modules with code and how they're connected:
pmalik is offline
post #10 of 14 Old 7th May 2019, 01:13 AM Thread Starter
Truenorth
I think I need to step up my game and get the Bavarian cable/program, Carly isn’t cutting it after seeing this. Thanks for taking the time to post it. Still waiting to hear back from the shop.
MPG SHOOTOUT: AMC Gremlin vs. BMW M6 David Ajax III E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 28th July 2010 02:31 PM
Chasing a Coolant Leak - Part One Jboud8880 E39 M5 and E52 Z8 Discussion 10 18th April 2009 05:09 PM
Weird audio gremlin mottati E39 M5 and E52 Z8 Discussion 10 30th March 2006 03:18 AM
M3 E46 chasing Abt RS4 on Hockenheim Gabriel343 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 33 8th May 2003 01:05 PM
