E60 M5 rear differential leaking - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By sunghyun7
post #1 of 10 Old 23rd April 2019, 03:47 AM Thread Starter
sunghyun7
sunghyun7's Avatar
so my rear differential pumpkin is leaking.. probably the seals? I couldn't find any info on the DIY master thread. Is this a hard job? Other than popping out the seals and hammering new one in with mallet followed by changing diff fluid, is there anything else I should do while things are out? Thanks!
2006 E60 M5 with supersprint headers, mid pipe, and muffler without cat. Evolve R stage 3 tune.
sunghyun7 is offline
post #2 of 10 Old 23rd April 2019, 06:10 AM
Hasan Shaikh
Hasan Shaikh's Avatar
Its just like any other differential. Fairly straightforward if you know what you are doing; which it sounds like you do.
I would check all the bearings and gears.
Hasan Shaikh is offline
post #3 of 10 Old 23rd April 2019, 05:01 PM
flacoramos
Yeah you did rod bearings, you won't have trouble changing the diff output seals. I hope it's not the input seal, that one requires some disassembly.
flacoramos is offline
post #4 of 10 Old 23rd April 2019, 06:22 PM Thread Starter
sunghyun7
sunghyun7's Avatar
cool, thanks guys! probably a good thing. Was looking for a reason to raise up the car to do muffler bypass.
post #5 of 10 Old 23rd April 2019, 11:00 PM
tripz
tripz's Avatar
input shaft seal
Probably the input shaft seal which is a PIA. You need to take off the driveshaft, exhaust etc
I had mine replaced after noticing grease above the diff which was a result of leaking seal
tripz is offline
post #6 of 10 Old 23rd April 2019, 11:47 PM
flacoramos
The input is the most likely culprit, unfortunately.
post #7 of 10 Old 26th April 2019, 05:27 PM
Slamfire
Slamfire's Avatar
Depending on how bad it's leaking, if it is the input seal and it's livable I'd wait until you need to do a clutch job for all the labor in getting to it. Or it might be worth throwing a new clutch in preemptively with everything that needs to get removed.
07 6 speed E60 M5
12 6 speed E93 M3
Slamfire is offline
post #8 of 10 Old 26th April 2019, 07:25 PM Thread Starter
sunghyun7
sunghyun7's Avatar
post #9 of 10 Old 14th May 2019, 06:15 PM
tripz
tripz's Avatar
the clutch has nothing to do w the differential job, so Id replace the seal and input shaft bearing (~$200-250). The differential can get dirt inside once the seal is leaking.
The job involves dropping the driveshaft and taking down the heatshields in the back, easiest to drop at a shop.
tripz is offline
post #10 of 10 Old 14th May 2019, 11:31 PM
Al59751
Al59751's Avatar
Al59751 is offline
Press Release and official pictures (BMW M5 F10 Concept) Gustav F10 M5 Discussion 98 7th June 2012 05:36 PM
BMW 5 series Gran Turismo now official Gustav E60 M5 and E61 M5 Touring Discussion 32 18th August 2009 12:27 AM
Article and video:: Weekend with the BMW M5 E60 [From 2005] Gustav E60 M5 and E61 M5 Touring Discussion 4 30th December 2007 10:06 PM
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 03:43 PM
