Cic retrofit coding - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 14 Old 18th April 2019, 04:23 PM Thread Starter
sundaycruzers
Cic retrofit coding
I know itís been done, but can I code a cic to my 06 without using an emulator? And does anyone have the process for coding properly. Found endless diy for install and pin configuration but coding always seems cloudy. Plus Iím trying to understand the fsc code and combox retrofit. I know of the #0909 for fa. What else?
sundaycruzers is online now
post #2 of 14 Old 18th April 2019, 05:30 PM
flacoramos
Yes it can be done. The emulator is only needed to enable navi. I did this a few months ago and it was a PITA. Can't remember the details but getting the software to work was a pain. It involves wiping the cic public certificates and then installing your own - or something to that extent....
flacoramos is offline
post #3 of 14 Old 18th April 2019, 11:59 PM Thread Starter
sundaycruzers
Your talking about the fcs codes, correct?
post #4 of 14 Old 19th April 2019, 04:52 AM
flacoramos
Yes. Generating fsc codes is easy. Problem is updating the cic to enable all functions as vin doesn't match. That's what the emulator is for. Or the non emulator way to generate new fsc certificates with your vin. That's what fstool is for and a pain to get to run.
post #5 of 14 Old 19th April 2019, 04:56 AM
flacoramos
Here's a pdf to get you going. This and google intel123 patcher. There are more application numbers than what is in the pdf, just google them.
https://www.google.com/url?sa=t&sour...CcAml_5QOBrv7k
The Following User Says Thank You to flacoramos For This Useful Post:
sundaycruzers (19th April 2019)
post #6 of 14 Old 19th April 2019, 05:02 AM Thread Starter
sundaycruzers
post #7 of 14 Old 19th April 2019, 05:19 AM
flacoramos
Originally Posted by sundaycruzers View Post
Sounds like the fastest (easy) way is to use emulator, but vin coding is possible.
Probably. But I hate cutting the stock harness so...
And about cutting wires here's a tip: don't tap into the hazard switch harness when you add the front panel lightning wire. You can get the same signal on the ashtray harness. Makes routing way cleaner.
post #8 of 14 Old 19th April 2019, 05:20 AM
flacoramos
And aren't emulators like $100 these days? That's another reason to hate them even more. Software was free, but it did take a LOT of hours.
post #9 of 14 Old 19th April 2019, 05:30 AM Thread Starter
sundaycruzers
post #10 of 14 Old 19th April 2019, 06:11 AM
koudanshi
I think you need to retrofit first, second is for combox.
In order to change CIC VIN, you will need ICOM tool and flash CIC with new latest software + your VIN, then you can use Intel123 patches to patch your CIC and use FSC generator like Intel123 guide.
Good luck,
koudanshi is offline
BPMSport: Spring CIC iDrive Retrofit Sale! BPMSport M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 6 14th May 2015 12:09 AM
CIC Retrofit Experience & Lessons Learned jarrett E60 M5 and E61 M5 Touring Discussion 25 18th February 2015 07:30 PM
>>>Bimmer Retrofit: OEM CIC Navigation System Retrofits<<< BimmerRetrofit M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 14 17th October 2014 12:58 PM
>>>Bimmer Retrofit: OEM CIC retrofit kits!<<< BimmerRetrofit BMW M3 Group Buy Forum and Sponsor Discussion and Offerings 3 17th October 2014 12:55 PM
CIC Retrofit for BMW E63s - (Long and Pic Heavy) AlexMSFT E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 40 20th June 2014 04:33 PM
