The Limp Mode Ghost - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By flacoramos
post #1 of 8 Old 17th April 2019, 05:55 PM Thread Starter
Twoodgt
The Limp Mode Ghost
So for a couple weeks now anytime I use M mode and hit over 6 to 7 thousand rpms I get the old engine malfunction along with DSC AND DBC warning lights. Limp mode follows shortly there after. I stop cut the car off and restart it and alls good. All problems were pointing to a bad throttle actuator. But I discovered that if I’m not in M mode I have the full 400 hp all the way to red line without any problems at all. I would think that if an actuator were bad that it’s bad regardless of what mode I’m in. To add to the confusion the other day I decided to change from P500 plus back down to just P500. I drove the car for a day or two in this mode and yesterday I changed it back to p500 plus. Now for some reason my car pulls and drives like a brand new car. No limp mode in any mode and no codes WTF ?!?! I have a few upgrades and I was thinking that I was have an issue with one of those also. I have the ESS computer upgrade as well as the SMG upgrade with speed limiter removes and underdrive pulley. I also have the Rpi scoops and Super Sprint Exhaust (from headers back). I don’t know what’s going on but I did go ahead and order new gears for the Throttle Actuators just in case. I’m going to freaking enjoy it now unless old limp mode comes around again soon !!! If any of you can explain this please help a brotha out !!! Thanks
Twoodgt is offline
post #2 of 8 Old 17th April 2019, 06:13 PM
Ferris
Pull the codes...
but 400 hp works by limiting the fill , ie throttle to 80% and 500 hp mode the throttles don't open 100% below certain rpms( not in front of the tuning computer to tell you which exactly). So it's possible you have broken/missing tooth on the actuator btw the 80%-100% open range.
oth the actuators do self test not sure the exact criteria of that though.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #3 of 8 Old 17th April 2019, 06:38 PM
flacoramos
Sounds like fuel starvation to me. But like Ferris said you need to read the codes to know for sure.
flacoramos is offline
post #4 of 8 Old 17th April 2019, 06:54 PM
Ferris
I like this one, too I had a case of reading actuator and that's where my mind got stuck. I guess that's why we pull codes
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #5 of 8 Old 17th April 2019, 06:59 PM
jcolley
jcolley's Avatar
jcolley is offline
post #6 of 8 Old 17th April 2019, 07:18 PM Thread Starter
Twoodgt
I appreciate both answers. I sorry I didn’t mention. I pull the codes I can’t remember that actual code but one was the idle speed actuator and another was for clutch adaptation (I have had this one for a year). And of course the normal DBC and DSC malfunctions that are activated durning lisp mode. I had all the injectors replaced about 2 months ago because #5 was stuck open and hydro locked the engine and broke 2 starters (1st one was replaced before the mechanic knew what was going on). No fuel codes and not throttle actuator codes. But like I said after switching to P500 plus back to p500 only and then back to P500 plus again a few days later it pulls and feels like it has more power now than it has since I have had it.
Twoodgt is offline
post #7 of 8 Old 18th April 2019, 04:02 AM
AmstaffM5
So, to clarify - since you replaced all of the injectors you have had this issue?
Help the forum help you - be more clear.
AmstaffM5 is online now
post #8 of 8 Old 18th April 2019, 04:47 AM Thread Starter
Twoodgt
No that is not the case. I made mention of the injectors being replace because of one of the other members made a comment about fuel starvation. The car ran fine up until 2 weeks ago. I was on the interstate and drop it into 4th gear. I ran the rpms up to about 7500 and bam limp mode. I pulled over and shut it down. Once I restarted it the car ran fine unless I ran the rpms up again. I came home and pull the codes I got the normal DSC AND DBC faults along with the engine malfunction code. The only code that stood out was the U1139 idle control valve/AMT Communication Bus off the OEM code was CD8B Bus off Idle Speed Control Valve / SMG Can. I changed the fuel filter this weekend hoping it was only a fuel starvation issue but the symptoms stayed. But as I stated about if I ran the car with out activating M mode I have full rpm etc with no codes or limp mode being activated. So yesterday I decided to attempt to change my M settings from P500 Sport to P500 just to see if that would do anything. I went for a test drive and it continued to malfunction. A few hours later I change it back to P500 Sport. Once I did the car had more power than I can ever remember without limping out at any rpm. I don’t know what the deal is. Hope that cleared it up a little.
Twoodgt is offline
Needing help asap car m5 in limp mode azzy3915 E60 M5 and E61 M5 Touring Discussion 22 21st August 2018 02:57 PM
Idle Limp Mode MobiusOne E60 M5 and E61 M5 Touring Discussion 8 30th July 2018 05:39 PM
Limp Home Mode at 120 MPH la crosse E39 M5 and E52 Z8 Discussion 6 13th December 2010 06:34 PM
Limp Home Mode - Fully Explained Fitz E39 M5 and E52 Z8 Discussion 2 14th May 2008 10:44 PM
Troubleshooting power loss under full throttle & limp mode? polizieim5 E39 M5 and E52 Z8 Discussion 22 15th May 2006 02:34 PM
