CCC Display Dead - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 22 Old 17th April 2019, 05:38 AM Thread Starter
davidn32
davidn32's Avatar
CCC Display Dead
So my 2006 E60 M5 CCC display died, blank screen, no radio, SOS & control knob spins freely. Checked all the fuses & they are good. Do I need to replace the CCC screen itself only? Is it that simple to swap with another one or more to it? Thx!
davidn32 is offline
post #2 of 22 Old 17th April 2019, 08:32 AM
e39_415
e39_415's Avatar
The swap is not that difficult 2 T10 Torx fasteners. Once the fasteners are removed, pull the top of the iDrive display out of the dashboard. If needed, gently lever it out using a plastic prying tool. Once the top is free, lift the bottom of the display out from the mounts and remove it far enough to access the electrical connectors.
- RH
e39_415 is online now
The Following 2 Users Say Thank You to e39_415 For This Useful Post:
davidn32 (17th April 2019)
post #3 of 22 Old 17th April 2019, 03:55 PM
flacoramos
Screens are not known to fail - other than the rare case. The CCC unit on the other hand is a likely culprit.
flacoramos is offline
The Following 2 Users Say Thank You to flacoramos For This Useful Post:
post #4 of 22 Old 17th April 2019, 05:37 PM Thread Starter
davidn32
davidn32's Avatar
Thanks for the responses.....
Any way to test if the screen or the CCC unit is bad? Maybe easier just to buy a used set from member's here instead. If so, is it just a plug n play? Any re-coding necessary? Thx
davidn32 is offline
post #5 of 22 Old 17th April 2019, 06:36 PM
flacoramos
Only sure way is to swap parts - sorry.
Coding may or may not be necessary. Depends on whether donor car features matches yours. There may be some options enabled on the donors unit and/or viceversa. Either way basic stuff should work.
Blank / default coding is rather easy if you have a copy of ncs and a $30 K/Dcan cable.
post #6 of 22 Old 17th April 2019, 07:53 PM
e39_415
e39_415's Avatar
Another option of course is to upgrade to CIC if you don't feel like swaping parts.
- RH
post #7 of 22 Old 17th April 2019, 08:01 PM
JrMint03
I have a full CCC system if you want to buy. It has about 25k miles on it. I moved into a CIC a couple years ago and these parts are just sitting.
2007 E60 M5- Black Saphire
Eisenmann Race Exhaust
CIC Retrofit
Euro SMG Tune
RPI Scoops and Block off Plates
Lowtech Front Springs
H&R 12mm Spacers all around
Black Kidney Grills
LED Interior, License Plate and Side Marker Lights
2014 F10 M5- Alpine White
Gloss Black Front Grills
Gloss Black Side Grills
IND Painted Reflectors
BMC Drop in Filters
10mm Spacers all around
Other Rides-
2019 Jeep Grand Cherokee
2017 Mercedes GLE350
2015 Lamborghini Aventador Roadster LP700-4
2015 Lamborghini Huracan LP610-4 Twin Turbo
JrMint03 is offline
post #8 of 22 Old 17th April 2019, 08:22 PM Thread Starter
davidn32
davidn32's Avatar
Thx, I'd prefer minimal cost as possible, as this is my weekend car (don't drive it much). Mine is an '06 M5 (probably 1st generation CCC unit). I noticed others with '08 + has a different display? Mine doesn't have the numbers 1-6 radio face. Just has a CD & DVD slot (underneath the climate control knob).
So if anyone has a similar CCC setup that will work on my car, please pm me. Not looking to spend a whole lot....Thx
davidn32 is offline
post #9 of 22 Old 17th April 2019, 10:26 PM
gpeterson
If you do need just the screen I have one that I'd sell. I'd also loan it out for testing it you want to cover shipping, but it does sound like you have more than a screen issue.
gpeterson is offline
The Following 2 Users Say Thank You to gpeterson For This Useful Post:
davidn32 (18th April 2019)
post #10 of 22 Old 18th April 2019, 04:44 AM
JrMint03
Mine is from an 07
CIC Retrofit
Euro SMG Tune
Black Kidney Grills
BMC Drop in Filters
Other Rides-
JrMint03 is offline
Dead pixels - dashboard display Michael_s E39 M5 and E52 Z8 Discussion 27 30th July 2013 06:56 PM
CCC Japanese to Euro Conversion Streb E60 M5 and E61 M5 Touring Discussion 0 14th October 2010 09:22 AM
How to remove light scratches on 16:9 widescreen display gavinbailey E39 M5 and E52 Z8 Discussion 7 22nd July 2009 10:10 PM
Dead pixels in temperature display an expensive fix? RRL E39 M5 and E52 Z8 Discussion 11 25th June 2007 04:56 PM
