SMG Hydraulics Failure analysis - Page 2 - BMW M5 Forum and M6 Forums
 5Likes
post #11 of 18 Old 9th May 2019, 06:34 PM
335xi
So, how easy is this to do?
Originally Posted by Ferris View Post
Wanted to throw a quick follow up and observations. Now that I replaced my Real main I've got a chance to do a lot more observations in inpa.
I wish I had a chance or at least forethought to log some data when the car was new. Now, after the rebuild, though there is little to no pressure drop when cruising in the same gear or over night. The pump rarely kicks on when opening the door or unlocking, Also it looks once the clutch is pushed in , ie at a light, there is hardly any pressure bleed. As we'd expect pressure drops when gears or the clutch moves. Also pressure builds right away right after the pump kicks on.
These are merely just data points , I wish I knew earlier. I may try to get testo to log all this so we can get into a spreadsheet.
Is the pump basically 2 halfs or will it spill a bunch of parts once opened?
335xi is offline
post #12 of 18 Old 9th May 2019, 06:38 PM Thread Starter
Ferris
The pics are above to give you an idea, but basically it's a body two end caps, seals, and gears.
It's a basic hydraulic pump design.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #13 of 18 Old 9th May 2019, 06:48 PM
335xi
yeah, never opened a pump up before
But if I could open without parts spilling out, putting new oring in and closing it back up that would be something I can handle.
335xi is offline
post #14 of 18 Old 9th May 2019, 06:54 PM Thread Starter
Ferris
Well I don;t know you so I can't make that call....
Seriously though it's very simple part orientation matters at least in terms of the bronze sealing plates . So just take your time and pay attention and you'll be fine.
If you get stuck mail me the parts and a cup of coffee and i'll reassemble it for you
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #15 of 18 Old 10th May 2019, 04:30 PM
h8c18
h8c18's Avatar
Rebuilding my spare SMG Pump
Thanks for the information and thread. I will be rebuilding the one that just came out my car. I saw and item on ebay for the shaft driven off the electric motor. Has anyone replaced that whole doing this? Mine is beat up where the coupler connects.
Cheers
h8c18 is offline
post #16 of 18 Old 10th May 2019, 04:38 PM Thread Starter
Ferris
Cheers
Post pics I'd like to see a gnarled up shaft, the coupling should've taken all the abuse not the shaft.
I don't think anyone has here replaced the shaft gear, as long as they're manufactured to proper tolerance you should be fine.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #17 of 18 Old 18th May 2019, 08:51 PM
J.R ///M5
J.R ///M5's Avatar
Transmission overhaul is done. Car got new clutch, flywheel, slave cylinder, transmission mounts, SMG-acculator, SMG-electric motor, new o-rings for solenoids (from Fast attack motorsport) and SMG-hydraulic pump internal seals and "unicorn piss" hydraulic fluid (from Burkhart engineering).
Before repairs it took almost 8s to SMG prime in the mornings and got a sqeeking sound when changed gears. Now it takes 1.5s to prime and squeeking sound is gone. Sound was coming from throwout bearing which was original and it was sticking. Old SMG-hydraulic pump internal seals were in good condition.
BMW E61 ///M5 -07
Ex. BMW E39 ///M5 -01
Current mods: Short shifter, Custom clutch stop, Alpha-N + Power tuning by Evolve, AP coilovers, HEL brake lines.
J.R ///M5 is online now
post #18 of 18 Old 19th May 2019, 02:54 AM
h8c18
h8c18's Avatar
h8c18 is offline
E60 M5 SMG Trans Pump Failure E60 M5_NJ E60 M5 and E61 M5 Touring Discussion 3 8th January 2019 11:22 PM
Power Steering Pump Caused SMG Failure???? loud068 E60 M5 and E61 M5 Touring Discussion 8 20th June 2018 08:07 PM
SMG failure, owning car for 1 week Pav E60 M5 and E61 M5 Touring Discussion 22 16th February 2018 05:22 PM
(video) SMG Trans Unique Failure | New Clutch & Flywheel umichchris E60 M5 and E61 M5 Touring Discussion 34 1st July 2014 08:04 PM
SMG Press Release Omar E39 M5 and E52 Z8 Discussion 12 18th February 2001 10:45 PM
