S85 Rebuild Project - BMW M5 Forum and M6 Forums
post #1 of 21 Old 10th April 2019, 10:52 PM Thread Starter
networx
Question S85 Rebuild Project
Hi everyone, I'm new here. I came across a 2006 E60 M5 for about $10k. It runs well and has about 120k miles on it. I'm thinking of making it a project to rebuild the engine. I'd like to know what to expect if I go down an endeavor like this. What I would like is something as quick as possible, not opposed to turbos or superchargers, but would like to have it run on 91 octane if possible. I kinda want this as a DIY project, I've never really rebuilt an engine before, (As a kid I did watch my dad rebuild a for 302).
So I guess my question is, what should I expect? Cost-wise?, What parts/kits should I be looking for in a rebuild? Ideally, the rebuilt engine will last another 100k+ miles. I'll probably be upgrading other areas as well, like the brakes, suspension, exhaust etc, all of which I am familiar with replacing. It's just the engine rebuild I've never done.
I appreciate any feedback/direction.
-Russ
networx is offline
post #2 of 21 Old 10th April 2019, 11:33 PM
Ferris
Don't conflate the the goals
If you want to address possible issues such as rod bearings you should address them.
If you want to rebuild it because reasons, it's not really a wyotech intro to engine rebuilding engine. There is a bed plate, oil pump that requires lash adjustments, a **** ton of special tools and procedures, and other items that are not really like rebuilding an old push rod v8, now don't get me wrong it's not rocket science but it's also not an engine to learn on either. It's also quite expensive parts wise.
If you want to do power adders like super chargers then there are kits that run on stock engine.
If you want to go balls out you need to address if you're going on NA power or forced induction and build accordingly.
I guess what I'm getting at is what exactly is your goal?
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is online now
post #3 of 21 Old 11th April 2019, 12:24 AM Thread Starter
networx
hmm, i guess i never really thought about it outside of the bounds of
a) new 2019 m5 comp is shiny but way too expensive
2) i want to get as close to that as possible without spending $140k
idk, it sounds to me like youre saying that the tech in the enginer is specialized enough that i may spend that difference on the tools required to work on it anyway?
networx is offline
post #4 of 21 Old 11th April 2019, 12:26 AM Thread Starter
networx
i was also going on the (maybe false) assumption that I can youtube how to rebuild it as well, given how popular of an engine it is.
networx is offline
post #5 of 21 Old 11th April 2019, 01:10 AM
Ferris
I mean in the end it's still just an engine. It does take a lot of special tools and procedures.
I suggest you check out the factory procedures to see what you're getting into
https://www.newtis.info/tisv2/a/en/e...als/11-engine/
2001 E39 M5
2010 E60 M5
2008 E90 335xi
post #6 of 21 Old 11th April 2019, 01:18 AM Thread Starter
networx
networx is offline
post #7 of 21 Old 11th April 2019, 01:21 AM
Ferris
The S63 makes nice power, trying to chase it's output while being naturally aspirated is going to an expensive endevour. You really can't compare the two and they're completely different animals.
People have added superchargers to the S85 and that's probably your best and most cost effective approach. Look into Gianni or ESS for kits that are out there.
Custom turbos are possible and will put out bigger power but tuning will eat more of your time and budget than the turbos.
Honestly you'd be better off getting an 550 with N63 and kicking up the boost with tuning and bigger turbos, as a path of least resistance to making a f90m5 killer.
or getting a F10 M5 as starting point, they're getting hell of cheap too.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
post #8 of 21 Old 11th April 2019, 02:13 AM
Beniki
Beniki's Avatar
I suppose you need to start with the question: why do you want to rebuild the engine - Is it because the engine has suffered some sort of failure, or because you are chasing more power? The answer to this question will guide your decision making.
If the latter, then I suggest starting off looking at options around the path-of-least-resistence, which is no doubt supercharging in combination with addressing the known weak points of the motor (rod bearings and VANOS line at a minimum). My understanding (not from my own experience but from reading reports of others), is that this is something you can tackle at home.
Fully rebuilding an engine at home, with no prior experience or equipment; I can only see this being tackled if you have a lot of patience, plenty of clean space, and budget (time and money) for making mistakes.
Beniki is offline
post #9 of 21 Old 11th April 2019, 05:22 PM Thread Starter
networx
wow, good stuff. So, yeah, my goal will be to add power and extend the life of the engine. im seeing from responses that doing a full rebuild is probably not a good first step. i'm assuming if i decide to do this then at a minimum I should start with an overhaul kit like this: https://www.turnermotorsport.com/p-3...-overhaul-kit/ ?
Also, as another question, if I buy the car for $10k how far will dumping an additional $15k into it get me? if the answer is "not very far" then i might rethink this whole thing. but if i can get some good work done then i might give it a shot. of course not doing a full rebuild that requires a lot of specialized tools etc.
networx is offline
post #10 of 21 Old 11th April 2019, 07:47 PM
Slamfire
Slamfire's Avatar
15k is a healthy budget, though I'd rather find a more sorted (manual) M5 with most work done to it already for 25k than a 10k 8 owner craigslist special dealing with who knows how many headaches down the road.
For a beater M5 you're prob going to have to catch up on a lot of deferred maintenance. All your fluids, spark plugs, and almost guarantee rotors/pads are easy though you'll need a computer to bleed the brakes. Maybe ignition coils, looking about time for 2 throttle body actuators and 2 idle air actuators. Need to do bearings, which while you're there might as well do the vanos high pressure line and motor mounts. I'd also look at a set of decent tires and any worn suspension bits. If you need to drop the SMG for work, look into doing the rear main seal on the diff as they seem to go with age.
I'm sure some else can chime in with what the SMG might need, I'm a snobby manual elitist with no 1st hand ownership experience.
With buying your own parts being smart where you get them, and having all that done at a good german indy; I feel pretty confident all that work could get done for under 15k at least where I am.
91 should be the lowest that you put in car. If that's all you get in your area I get it, but go 93 if you can.
Power also doesn't come cheap, headers, exhaust, under drive pulley, tune, and intake scoops may net you 70+ horses on a tired motor but at over 6k installed. Any more power and you're looking at a stroker build or supercharging.
I'd make sure it runs right before going down that rabbit hole.
07 6 speed E60 M5
12 6 speed E93 M3
Slamfire is offline
S85: Updates through out the years. 5soko E60 M5 and E61 M5 Touring Discussion 51 28th November 2018 05:56 AM
caliper rebuild, master cylinder, Castrol SRF React, INPA ABS bleed uhad2point E39 M5 and E52 Z8 Discussion 12 29th August 2018 09:35 PM
BrenTuning | E60 M5 / E63 M6 S85 Tuning solutions BrenTuning M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 66 3rd March 2017 04:23 AM
Online project record LHD #231 (update on engine rebuild) raymondw E28 M5 Discussion 0 11th July 2009 11:31 AM
Possible to swap S85 with SMG into a different chassis? mattyice E60 M5 and E61 M5 Touring Discussion 16 28th June 2009 06:34 AM
