clutch adaptation - risk? - BMW M5 Forum and M6 Forums
post #1 of 12 Old 10th April 2019, 08:33 PM Thread Starter
gpeterson
I have a 2007 M5 with 106k miles. I get the clutch position deviation code (can't remember the number, will post an update) and feel like things don't work as smoothly as they should. Sounds like it could be the release bearing sticking but I don't feel like dropping the transmission and buying a new clutch yet if I don't have to. I'm thinking about replacing the SMG CHF11S and read (from @jcolley ?) that adaptation should be performed afterwards. I believe I also read adaptation could fail if there are issues with the clutch/flywheel/release bearing/pivot pin/etc.
Is adaptation necessary when changing the fluid? Should I risk it? Isn't bleeding a separate procedure?
Could a 2nd SMG ECU be a backup plan? (install ECU, adapt, put old ECU back if adaptation fails)
gpeterson is online now
post #2 of 12 Old 10th April 2019, 11:20 PM
Pav
Bleeding is separate procidure, you can run as many time as you need without any risk. Clutch adaptation is risky cause you can find yourself in situation when have to change clutch components in order to complete adaptation.
Sent from my LYA-L29 using Tapatalk
Pav is offline
post #3 of 12 Old 10th April 2019, 11:26 PM
Ferris
What @Pav said
If you're having issues and codes it's better to fix the problem before running the adaption. If it fails you'll be forced to fix it, rerun and pray till it works, or tow it to a shop.
No need to adapter after changing fluid, but then I also don't think changing the fluid would do anything other than make a mess and introduce the possibility of debris.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is online now
post #4 of 12 Old 11th April 2019, 12:22 AM Thread Starter
gpeterson
Anyone have thoughts on running adaptation with a spare SMG ECU installed? Seems like that may be a safe way to try adaptation without the worry of making the car inoperable.
post #5 of 12 Old 11th April 2019, 01:25 AM
Ferris
Minus the cost nothing wrong with that approach.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
post #6 of 12 Old 11th April 2019, 03:52 AM
flacoramos
This ^
And this ^
flacoramos is offline
post #7 of 12 Old 12th April 2019, 06:35 PM
335xi
Interested in this as well. I would like to replace the fluid..Need more confirmation if that can be done with no ill effects and no adaptation needed.
335xi is online now
post #8 of 12 Old 13th April 2019, 02:51 PM
jcolley
jcolley's Avatar
jcolley is offline
post #9 of 12 Old Today, 04:41 AM
Crimson1
Crimson1's Avatar
Wait, so running an adaptation can brick my ECU if something doesn't check out? Surely there's a way around this, like spoofing inputs from sensors, or SOMETHING?
EDIT: Maybe I'm overreacting. If something is far enough out of spec that the TCM is throwing a code, it probably needs to be resolved to prevent a more serious problem later on (dependent upon how conservative the "acceptable" ranges for the respective measurements are, I suppose).
Crimson1 is offline
post #10 of 12 Old Today, 05:37 AM Thread Starter
gpeterson
Temporarily "brick" your car due to exposing underlying mechanical issues/wear that must be fixed, not brick (int the traditional sense) the TCU.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
gpeterson
Clutch Adaptation Active w/4F67 Mlrsguy1982 E60 M5 and E61 M5 Touring Discussion 32 24th December 2018 12:12 PM
Clutch Adaptation... yes or no? paulclaude E60 M5 and E61 M5 Touring Discussion 11 22nd April 2015 03:34 AM
UUC Direct fit performance organic issues HJB1988M5 E39 M5 and E52 Z8 Discussion 376 26th June 2009 06:02 PM
Installed: Clutch Stop for my Bi-Turbo puppypilgrim ALPINABoard.com | BMW Alpina Discussion 6 25th October 2006 02:44 AM
