2006 leaking hydraulic fluid from trans - BMW M5 Forum and M6 Forums
LinkBack Thread Tools Rate Thread
Old 10th April 2019, 05:25 AM Thread Starter
Tawitt
Hello all, I have an 06 with just under 70k miles and got a transmission failure message with a red gear whenever I would come to a stop. Once driving even at 2 mph the message would go away. About 5 miles later when coming to a stop the car died and would not start again, didn’t even turn over. I towed the car home and notice hydraulic fluid on the flat bed. I removed the panel below the engine which was covered in fluid. Sprayed down the bottom side to remove any fluid and refilled the hydraulic fluid, which I’m guessing was pretty much empty by how much fluid it took. Tried to restart the car but it was the same as before. Raised the car back up and noticed the hydraulic fluid steadily dripping where the trans and engine meet. Any ideas as to what this may be? Any suggestions would be helpful.
Tawitt is offline
Old 10th April 2019, 05:49 AM Thread Starter
Tawitt
I should also mention there are quite a bit of codes under the transmission. I have the following fault codes. 4FAO activation clutch 520B transverse acceleration 5201 wheel speed LR 5202 wheel speed RR 5203 wheel speed LF 5103 voltage supply, battery voltage520A steering angle sensor 5101 hydraulic press sensor
Tawitt is offline
Old 10th April 2019, 05:56 AM
Dwynell
Dwynell is offline
Old 10th April 2019, 06:00 AM
TexaZ3
TexaZ3's Avatar
Yup, I would almost bet on the slave. At 70K, I would also check your TB and guide bush as well, since you will be taking the gearbox down.
E36 1999 M3 Coupe Dakar Yellow/Black Vaders
E36 2000 M Coupe Cosmos Black/Black Leather, Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein.
E39 2000 M5 Imola/Black Heritage
E46 2005 M3 Coupe ZCP Carbon Black/Black
E63 2006 M6 Coupe Indianapolis Red/Black/Madeira, Style 343
TexaZ3 is offline
Old 10th April 2019, 07:57 PM Thread Starter
Tawitt
Thanks for the responses. I already ordered a slave cylinder and clutch kit. Anything I should be aware of while doing this? Your advice is much appreciated.
Tawitt is offline
Old 10th April 2019, 11:20 PM
Ferris
Might as well replace the guide tube too. Also make sure the trans input shaft seal isn't leaking. You'll need a special torx bit to remove the flywheel if plan on removing as part of doing the pilot bearing. If your rear plenum crankcase tubes are cracked it's a good time to replace them while the trans off. I suggest replacing the flywheel but that's just me and get new bolts for the pressure plate.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
Old 10th April 2019, 11:37 PM Thread Starter
Tawitt
I’m not seeing a guide tube as a part. Would this be a shift bushing? Pardon my stupidity, I’m new to this European thing.
Tawitt is offline
Old 10th April 2019, 11:46 PM
Ferris
Originally Posted by Tawitt View Post
Iím not seeing a guide tube as a part. Would this be a shift bushing? Pardon my stupidity, Iím new to this European thing.
P/N 23117564680
You should book mark BMW Parts Catalog
Also while the trans is out, you might want to consider repairing the senor strip on top of it. Though there are tons of cautionary statements with that, but the wires have shitty insulation that crack and fray and lead to shorts.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
Old 10th April 2019, 11:49 PM
Ferris
it also doesn't hurt to replace the clutch fork , pin, and spring clip as they're cheap.
one More addendum...
You don't NEED the special alignment tool, the Luk kits come with a generic one that works, not sure about the sachs though luk uses sachs go figure. Though it makes it a little easier and you can rent one.
The goal of the special tool is to prevent the clutch from coming apart , DON'T TAKE IT APART, as it's a 4 piece clutch. The Pressure plate, internal disk and plate are pretty solidly together it's the last disk that is loose.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
Old 10th April 2019, 11:52 PM Thread Starter
Tawitt
It pulled up a release bearing guide. I attached a pic of the part number.
Tawitt is offline
Rate This Thread
E60 For Sale: bosch platinum iridium fusion #4503 spark plugs (8) sickmint79 Parts / Other For Sale or Wanted 0 31st August 2014 10:04 PM
2006 m5 leaking oil from crank seal jeffdecourse E60 M5 and E61 M5 Touring Discussion 5 20th June 2010 11:07 PM
UUC SSK, RP Fluid, RE Trans Mounts - First Thoughts M-FŁnf E39 M5 and E52 Z8 Discussion 18 1st July 2003 05:20 AM
Interesting letter about clutch slippage.. M5Bob E39 M5 and E52 Z8 Discussion 33 10th April 2002 09:27 PM
