2006 leaking hydraulic fluid from trans - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 20 Old 10th April 2019, 11:58 PM
Ferris
Originally Posted by Tawitt View Post
It pulled up a release bearing guide. I attached a pic of the part number.
Welcome to M5board where pics work only some of the time...
Here is a link to it on FCP, they have it for 18 and ecs has it for 40 something, which is funny because ecs is usually better price wise.
https://www.fcpeuro.com/products/bmw...ve-23117564680
What you'll find is the current one is marred and galled from the old metal style through out bearing.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #12 of 20 Old 11th April 2019, 03:49 AM
flacoramos
This is my list of stuff to-do while you're in there.
https://www.m5board.com/vbulletin/e6...fc#post7536564
For clutch and flywheel check rockauto. For bmw-only parts use bmwpartshub.com or bmwdirectparts.com . Unless it's a sale item they are way better than fcp or ecs. Seems fcp price may be a typo on this, buy while you can.
flacoramos is offline
post #13 of 20 Old 11th April 2019, 03:54 AM
Ferris
Rock has the clutch for 488 and flywheel for 819, at least they did last month
The fcp price is legit, I paid 15 for it last month from them as well
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #14 of 20 Old 11th April 2019, 06:42 PM Thread Starter
Tawitt
Tawitt is offline
post #15 of 20 Old 11th April 2019, 09:03 PM Thread Starter
Tawitt
Another question. I’m looking up clutch kits and it looks like a couple different kits. As you all probably know there are Non sequential and Sequential. What one do I need. Rock auto has a LUK 03083 Non Sequential kit or a LUK 03090 Sequential kit. When I go through my parts supplier it lists the 03083. Being that I have a Sequential Manual Gearbox it makes me think I need the Sequential. Help please
Tawitt is offline
post #16 of 20 Old 12th April 2019, 12:15 AM
flacoramos
post #17 of 20 Old 16th June 2019, 03:58 PM
CarbonCinco
Hey guys sorry to revive a kinda old thread. I recently purchased a 2006 E60 M5 with the same issue, bunch of SMG codes like the one above. Found out the slave cylinder was leaking, clutch and flywheel looked good. We replaced it and put the car back in the air and still no start, Neutral light flashes car won’t go into any gears or start. Is it true I have to reset the trans through INPA? Hoping this fixes it. Thanks! I thought it would be plug and play and not need anything to be reset
CarbonCinco is offline
post #18 of 20 Old 16th June 2019, 05:15 PM
flacoramos
post #19 of 20 Old 16th June 2019, 06:09 PM
pmalik
Err don't you have to drop the trans to swap out the slave? I thought the bolts on it are on the inside of the bellhousing for some reason.
pmalik is offline
post #20 of 20 Old 16th June 2019, 11:02 PM Thread Starter
Tawitt
Tawitt is offline
E60 For Sale: bosch platinum iridium fusion #4503 spark plugs (8) sickmint79 Parts / Other For Sale or Wanted 0 31st August 2014 10:04 PM
2006 m5 leaking oil from crank seal jeffdecourse E60 M5 and E61 M5 Touring Discussion 5 20th June 2010 11:07 PM
UUC SSK, RP Fluid, RE Trans Mounts - First Thoughts M-Fnf E39 M5 and E52 Z8 Discussion 18 1st July 2003 05:20 AM
Interesting letter about clutch slippage.. M5Bob E39 M5 and E52 Z8 Discussion 33 10th April 2002 09:27 PM
