Charged - ESS VT2 675 - Page 3 - BMW M5 Forum and M6 Forums
 4Likes
post #21 of 34 Old 20th May 2019, 09:39 PM Thread Starter
Awbimmer
Originally Posted by Slamfire View Post
Glad to hear that your car is getting sorted, albeit slowly. Hopefully you're tearing up asphalt shortly.
Sometimes I long for having another 120 ft/lbs of torque in mine but am reluctant to dump the $$$ into supercharging / all the required supporting mods because of stories like yours and dealing with my own problem children in the past. If I have any luck it's bad luck, and bad luck sucks with a 100k mile plus V10.
Believe me, I too have bad luck! It was never intended to be charged but came across a deal on a new kit and couldn't pass up! That torque and linear power delivery is UNREAL. You must do it if you can!!
Awbimmer is offline
post #22 of 34 Old 20th May 2019, 09:46 PM Thread Starter
Awbimmer
Originally Posted by triksterut View Post
I'm sure the experts have checked this - or maybe it's not a thing on this platform - but I had some issues with my E46 like this that were the short/long term fuel trims being set. The alpha-n tune no longer used them (I think) and it wasn't updating them. Had to zero those out and I haven't had any issues since.
Yeah so I think this is a map/tune related issue or atleast I really hope so! Thanks for the heads up. I'll wait to hear back form my indy and go from there.
Awbimmer is offline
post #23 of 34 Old 20th May 2019, 09:49 PM
Slamfire
Slamfire's Avatar
Seriously its so tempting. Just need to convince the wife or somehow make her think that it's her idea. If anyone has any ideas I'm all ears.
The 20k I'd imagine it would take to get the kit, supporting bits, and installed would go a long way for getting another M car for the stable though.... both horsepower and cars are far too expensive of an addiction.
07 6 speed E60 M5
12 6 speed E93 M3
Slamfire is offline
post #24 of 34 Old 20th May 2019, 09:54 PM Thread Starter
Awbimmer
Well if you put it like that then yeah, another M car would be a good idea.... either way, make sure you have a spare room in the crib for when the Wife finds out it wasn't just an air filter, but a super charger
Awbimmer is offline
post #25 of 34 Old 20th May 2019, 11:07 PM
ACG
ACG's Avatar
I think the Gen 2. is considered the VT2-675 kit as it has the one piece intake complete with couplers, filters and hardware that gives it the 25hp. They also have the Gen.2 heat exchanger and the complete 8rib beltdrive system.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression 5.1L Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights / Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions / CF Trunk Spoiler
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, Pearl white
ACG is offline
post #26 of 34 Old 20th May 2019, 11:27 PM Thread Starter
Awbimmer
That is interesting. The cost difference between the 2 kits is few hundred dollars. However, I emailed ESS who said the difference is almost $5k due to new intake manifold and other hardware. I found this insanely bizarre.
https://esstuning.com/s85-vt2-675-su...-system-gen-2/
Looks to me that the 675 kit manifold still has to halves to it. Also the newer kits have silicon charge pipes whereas I have (and prefer) the metal charge pipe.
Awbimmer is offline
post #27 of 34 Old 20th May 2019, 11:44 PM Thread Starter
Awbimmer
I'll wait to hear from my shop if my kit is 650 or 675 VT2.
Fingers crossed the latter!
Awbimmer is offline
post #28 of 34 Old 20th May 2019, 11:56 PM
ACG
ACG's Avatar
I am just going by what they told me as I have all the Gen 2 upgrades being installed in a few weeks along with a meth kit. The prices per part adds up to around 3.5k if I recall.
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
KW V3 Coilovers
RIDES:
ACG is offline
post #29 of 34 Old 11th July 2019, 12:13 AM Thread Starter
Awbimmer
Sorry for my ignorance here, I really thought I had replied. Apologies.
How are you getting on with the build?
Awbimmer is offline
post #30 of 34 Old 11th July 2019, 12:19 AM
ACG
ACG's Avatar
The meth kit has been installed and the car is being picked up by ESS today (two different shops working on the car). I thought the car had already been collected but there seems to have been some miscommunication between who was delivering the car.
I will probably not hear back from ESS for a few weeks on the results as I am having an additional item installed that has not been unofficially released yet
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
KW V3 Coilovers
RIDES:
ACG is offline
ESS VT2 675 Supercharger on the way - UK Awbimmer E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 3 3rd January 2019 12:38 PM
How many ess charged m6s? michaelsevilla E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 13 19th June 2014 08:40 PM
ESS VT2 580 Upgrade-Impressions havasusteve03Beast E39 M5 and E52 Z8 Discussion 42 9th June 2013 04:35 PM
ESS VT2 600 E92 M3 Vs ESS VT1 535 E92 M3 Video LostMarine E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 40 3rd October 2012 04:22 PM
