Charged - ESS VT2 675 - Page 2 - BMW M5 Forum and M6 Forums
 2Likes
post #11 of 17 Old 7th April 2019, 09:52 AM Thread Starter
Awbimmer
Originally Posted by Hasan Shaikh View Post
Do you have any fault codes related to the thermostat or the ambient temp sensor?
Hi Hasan, No new codes other than ones i am aware of. I've always had a battery drain sign for a long time and input that down to a faulty CD reader in my CCC coupled with my audio build that I'm sure is drawing more more.
I had the CD reader changed thinking drain problems will go away but no. Even if my car is on tender charger itll still come up with a sign 1st thing and then after a drive itll go away.
Sent from my SM-G950F using Tapatalk
Awbimmer is offline
post #12 of 17 Old 8th April 2019, 01:19 AM
sunghyun7
sunghyun7's Avatar
Usually starting fuel table is based on coolant temperature. Try switching out coolant temperature sensor, if that doesn't work, ask him to increase fuel pump function during start up above certain coolant temperature. Interesting find. Please keep us posted. Thank you. Ps. by fuel pump function, I meant increasing fuel delivery.
2006 E60 M5 with supersprint headers, mid pipe, and muffler without cat. Evolve R stage 3 tune.
sunghyun7 is offline
post #13 of 17 Old 8th April 2019, 03:43 AM
flacoramos
This. I bet it's a start map issue.
flacoramos is offline
post #14 of 17 Old 8th April 2019, 02:10 PM
Beniki
Beniki's Avatar
Not sure if this is at all helpful, as I do not know the E60 fuel system that well, however I had a similar issue with my E53 4.8is, whereby it would start fine when cold but not well (extended cranking) when warm. Turned out to be a faulty check value on the return line.
Beniki is offline
post #15 of 17 Old 8th April 2019, 02:18 PM Thread Starter
Awbimmer
This is interesting. I will be changing my coolant temp sensor this week and have just bought a new crankshaft sensor that will swap too.
I'll do it in step procedure so I know what caused my issue.
Awbimmer is offline
post #16 of 17 Old 8th April 2019, 02:19 PM Thread Starter
Awbimmer
ESS have sent me the same file they sent originally which means they csnt be making the mistake on 3 different ocassions ....
Awbimmer is offline
post #17 of 17 Old 8th April 2019, 04:23 PM
flacoramos
Not sure what you mean. If their map has an issue, they can send it 100 times and still have the same issue...
The Following User Says Thank You to flacoramos For This Useful Post:
Beniki (10th April 2019)
ESS VT2 675 Supercharger on the way - UK Awbimmer E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 3 3rd January 2019 12:38 PM
How many ess charged m6s? michaelsevilla E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 13 19th June 2014 08:40 PM
ESS VT2 580 Upgrade-Impressions havasusteve03Beast E39 M5 and E52 Z8 Discussion 42 9th June 2013 04:35 PM
ESS VT2 600 E92 M3 Vs ESS VT1 535 E92 M3 Video LostMarine E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 40 3rd October 2012 04:22 PM
