O-rings for SMG pump - BMW M5 Forum and M6 Forums
 3Likes
  • 3 Post By GregZ
post #1 of 3 Old 27th March 2019, 02:49 AM Thread Starter
GregZ
Hi All,
The following is without any guaranty, this has worked for me it may not work for you. Do it at your own risk.
I have refurbished my SMG pump (removed, cleaned, filed stamping on brushes - you can search for threads here on how to do this). For the reassembly one needs o-rings (preferably viton). I was unable to find size specs, so I measured and ordered them from oringsandmore.com (around $15 for a lot of o-rings as they come in packs of 5,10, sometimes 50). Make sure you scroll down on their web and get the Metric Viton/FKM Orings
Here are the sizes:
- 75.79x3.53mm (large for sealing container to pump body)
- 63x2mm (large for sealing motor against pump)
- 13x2.5mm (on container)
- 5x1.5mm (pump face small)
- 19x1.5mm (pump lip)
- 9.25x1.78mm (into container)
The metal band (clamp) on the container is 9mm wide. I got two stainless 9mm wide stainless hose clamps for $9 from ebay (Narrow Band 9mm Steel Hose Clamp 80-100mm Made in Germany Pack of 2 HC80-100/9)
I also got a liter of CHF 11S fluid on ebay for $15.
My container plug was cracked (which is $60 from BMW). I made another bolt; you can find the details here: https://www.m5board.com/vbulletin/e6...iner-plug.html (If you do this, be sure to use a viton o-ring around the bolt's head and be very-very careful on how much you tighten it).
While the relays were out, I opened them, cleaned them and carefully sanded the contacts to get rid of burn-ins (old school switch/relay refurbishing trick).
All-in-all $50 (and my o-ring collection grew). I hope to get another 50kmiles out of it. (And I also hope to win the lottery.)
I hope someone will find this useful.
2007 M6-E64
GregZ is offline
The Following User Says Thank You to GregZ For This Useful Post:
Pav (27th March 2019)
post #2 of 3 Old 27th March 2019, 08:11 AM
flacoramos
What??? No pics???
But yeah joking aside good info. Did you have the trans out or in the car? If out I would have added all the stuff from the top of the unit (gear position sensor, solenoid orings). Either way you were 2 screws away from replacing the clutch solenoid orings - made a nice shifting improvement on my car.
flacoramos is offline
post #3 of 3 Old 27th March 2019, 08:12 AM
flacoramos
Oh and the relay is (was) about $15. When sanding those contacts you take away some or all of the coating they have. You may have accelerated wear if that coating is gone.
Understanding the Motronic 1.2 ECU AseanAero E34 M5 Discussion 8 21st March 2018 03:20 AM
DIY: Rod bearing change ger E39 M5 and E52 Z8 Discussion 21 25th October 2017 03:03 AM
M5 E60 gearbox pump issues andygtt E60 M5 and E61 M5 Touring Discussion 0 2nd June 2015 12:39 PM
DIY: Modding Fuel Pump Assembly for the Aeromotive 11140 gzig5 E39 M5 and E52 Z8 Discussion 10 6th May 2015 05:58 AM
Intersting read on oil consumption jt2ma71 E39 M5 and E52 Z8 Discussion 7 18th August 2011 08:01 AM
