Stupid "fix" for high battery drain, clock reset, etc. - BMW M5 Forum and M6 Forums
 4Likes
post #1 of 13 Old 25th March 2019, 01:36 AM Thread Starter
sunghyun7
sunghyun7's Avatar
I'm not sure whether this has been discussed. I have been having issues with car resetting clock almost daily and having high battery drain message on every start-up. I reset my battery and did every forum fix available (with exception of switching out comfort module) without luck. Well, I found a "fix" for my issue.
Instead of hanging my keyfob near my garage entrance (about 15ft away from the car through 2 walls), I started putting my keyfob in the kitchen which is far away from my car. My issues disappeared. I think the detection range may be little further than what one can anticipate.
I'm not saying this is panacea, but it's worth a shot if you're having similar problems. Over one week with no reset or battery error message which has never happened before.
On a more important note, I just clocked in over 10k miles on ACL bearings and pleased to announce no issues whatsoever. I never meant to daily the car, but it's pretty much my daily now! I may clock in that 30-50k mile for bearing inspection sooner than later.
sunghyun7 is offline
The Following User Says Thank You to sunghyun7 For This Useful Post:
HM506 (25th March 2019)
post #2 of 13 Old 25th March 2019, 01:58 AM
HM506
Good to know, I am more like 15 feet away and still have the same symptoms you describe, I will try to put the keys in the bedroom and see if that works...I also read somewhere to also check the IBS Sensor on the negative battery cable...waiting on a part and will update once installed..
Sent from my SM-N950U1 using Tapatalk
HM506 is online now
post #3 of 13 Old 25th March 2019, 03:09 PM
sundaycruzers
It will save the smg pump also. I noticed this the other day. Pump will periodically cycle if keyfob is president and doors are unlocked.
sundaycruzers is online now
post #4 of 13 Old 25th March 2019, 05:53 PM Thread Starter
sunghyun7
sunghyun7's Avatar
that's good point too. I would make habit of locking the car in the garage and leaving the car key far away from the car or put it in some metal cage.
post #5 of 13 Old 25th March 2019, 05:55 PM
HM506
You speak of a metal cage...can I find that on Amazon!? If so what the heck to I search for! I am serious
HM506 is online now
post #6 of 13 Old 27th March 2019, 03:14 PM
Domrepkid
So i took mine in for routine maintenance and service rep told me there is a recall for a battery cable that needed to be replaced, it was a while since i drove mine as well and i noticed the clock was reset as well.
Domrepkid is offline
post #7 of 13 Old 28th March 2019, 05:50 AM
LA Bandit
LA Bandit is offline
post #8 of 13 Old 1st April 2019, 05:14 AM Thread Starter
sunghyun7
sunghyun7's Avatar
btw, i think my issue with clock reset and high battery drain message is over. this seems to be the definitive 'fix' for me for the above issues. would like to know whether it fixed the issues in your cases as well.
post #9 of 13 Old 15th April 2019, 07:31 AM
Bimmer_Pilot
A Faraday cage or shield is an enclosure that cancels out EM radiation using a mesh constructed of a conductive material. Conveniently enough there are Faraday pouches made specifically for key fobs that emit ID signals to prevent potential thieves from using equipment that can sniff their signal and reproduce it to gain access to the associated vehicle.
Bimmer_Pilot is offline
post #10 of 13 Old Today, 06:04 AM
HM506
Perfect, just got a 2 pack on Amazon... thanks!!!
HM506 is online now
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Boomster
Battery replacement options 20ducks E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 27 10th October 2015 02:56 AM
Reset clock indicator cocovs6 E39 M5 and E52 Z8 Discussion 5 23rd May 2013 04:03 AM
540i Mystery Battery Drain ColtonFrey E39 5 series Forum 11 20th December 2012 03:32 PM
Battery tender question.... leebro1 E39 M5 and E52 Z8 Discussion 27 12th April 2007 09:08 PM
Normal battery current drain madm5 E34 M5 Discussion 4 28th August 2005 11:17 PM
