Strange failure s85 - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By psing23
post #1 of 3 Old 23rd March 2019, 04:39 PM Thread Starter
tanaysim
Strange failure s85
Hi all,
While I was accelerating my m6 s85 stall around 7000rpm. The first error was flat tyre system failure. I thought a tyre was blown and stopped immediately. The car was running rough on idle and saw oil light. Turned off the ignition immediately. I took the car to the repair shop. Checked error codes. All cyl missfire plus vanos codes including low vanos pressure. I checked vanos pressure manually it is ok(80bars at idle). Then I checked compression values. All same. Now I am going to checking injectors. Could the problem be the DME? Any comments would be appreciated. Thanks
Tanay
tanaysim is offline
post #2 of 3 Old 23rd March 2019, 04:52 PM
psing23
psing23's Avatar
How is your battery? The cars are very sensitive to low power so it could be anything from battery, alternator, voltage regulator etc. but I would try to check that. Good luck.
Sent from my Moto Z (2) using Tapatalk
08 e63 M6 AW
02 e46 M3 TiAg - Track Toy
psing23 is offline
The Following User Says Thank You to psing23 For This Useful Post:
tanaysim (23rd March 2019)
post #3 of 3 Old 22nd April 2019, 06:01 AM
sr71_M5
sr71_M5's Avatar
sr71_M5 is offline
DIY: Oil Pump Failure Teardown s85 M5v10man E60 M5 and E61 M5 Touring Discussion 8 29th October 2015 02:22 AM
How many here have had a top radiator hose failure on the S38 ? AseanAero E34 M5 Discussion 23 19th January 2015 04:38 AM
Transmission failure or just a failure.... Rickadelic E60 M5 and E61 M5 Touring Discussion 10 5th July 2009 07:33 PM
Failure Warnings-All of them funf_meister E60 M5 and E61 M5 Touring Discussion 21 16th May 2006 06:12 AM
S38 Water Pump Failure Rod E34 M5 Discussion 0 3rd July 2000 06:02 PM
