E60 m5 - 6 speed clutch replacement - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 12 Old 22nd March 2019, 05:00 AM Thread Starter
Iceman2011
Iceman2011's Avatar
Looking for some guidance here. I am planning to replace my clutch and flywheel as I am getting the following error:
2B61 - gearbox input speed sensor sensor: slipping clutch.
Is there anything else needing to be swapped out ? Is the slave cylinder and clutch sensor only applicable to SMG ? Also I am being quoted 9.5 hour job, is that accurate?
Thanks in advance
Last edited by Iceman2011; 22nd March 2019 at 05:02 AM. Reason: Additional questions
Iceman2011 is offline
post #2 of 12 Old 22nd March 2019, 05:18 AM
flacoramos
flacoramos is offline
post #3 of 12 Old 22nd March 2019, 05:27 AM Thread Starter
Iceman2011
Iceman2011's Avatar
post #4 of 12 Old 22nd March 2019, 05:58 AM
Fiftytwoeighty
Fiftytwoeighty's Avatar
I just went through this exercise with my 6MT.
After 140,000 miles my clutch went out and went with a Bimmer World Clutch Masters FX350 clutch with their lightweight single mass steel flywheel. If you use a dual mass flywheel, it will be plug and play. The single mass requires a larger throw out bearing, which they are now supplying — thanks to me.
https://www.bimmerworld.com/Clutch-M...M8-HDFF-D.html
I’m about 250 miles into the 500 mile break-in period. So far...I’m loving it. The FX350 is a little more aggressive, coupled with the SM FW. It does chatter, but a little chatter is expected with this set up. An OEM DM FW wouldn’t chatter.
I was going to start a full thread, after my break-in.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =158,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; CKS coils w/swift springs, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Euro RestoMod track car: caged, 6 point FIA harness, FIA Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x8 BBS RK w/Dunlop StarSpec II; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is offline
post #5 of 12 Old 22nd March 2019, 06:21 AM Thread Starter
Iceman2011
Iceman2011's Avatar
Any reason you went with after market vs. OEM ? Did you change your slave cylinder and other items posted above ?
post #6 of 12 Old 22nd March 2019, 12:21 PM
fortim
I have to ask, why would any chatter be acceptable?
fortim is online now
post #7 of 12 Old 22nd March 2019, 02:08 PM
Slamfire
Slamfire's Avatar
When my clutch goes I've been eyeing a spec setup if nothing but price. 1800 for clutch and flywheel directly from them maybe cheaper getting it somewhere else.
SPEC Clutches & Flywheels: Auto Parts, Domestic, Import, Truck, Racing, Drifting :: Results By Car
07 6 speed E60 M5
12 6 speed E93 M3
Slamfire is offline
post #8 of 12 Old 22nd March 2019, 02:49 PM
Fiftytwoeighty
My car is making a little more power than stock and spends time at the track.
Yes, I replaced everything as wear items.
~Woody
~I FRACKING!
~Viva La Wolfpack!
post #9 of 12 Old 22nd March 2019, 03:01 PM
Fiftytwoeighty
A lightweight flywheel will chatter when your clutch pedal is depressed, it’s normal. My chatter is nominal and you can barely hear it, but it is there, in the background.
The heavy OEM steel DM FW will absorb much of the driveline noise and vibrations.
~Woody
~I FRACKING!
~Viva La Wolfpack!
post #10 of 12 Old 22nd March 2019, 09:06 PM
Skills
LOL... "My car is making a little more power than stock"... #understatement
Skills is offline
NorCal - Bay Area Members Thread EuroCarFan USA West Forum 797 17th October 2018 05:24 PM
DIY: E60 M5 Master DIY Thread petesamprs E60 M5 and E61 M5 Touring Discussion 100 13th September 2018 08:54 AM
UUC Clutch Stop Install, Don't Sacrifice skippystahl E39 M5 and E52 Z8 Discussion 3 5th May 2017 03:52 PM
From an F10 M5 Owner: Things I miss about the E60 M5 BMWDave E60 M5 and E61 M5 Touring Discussion 57 10th April 2015 09:38 AM
CNS Racing Presents the Worlds first E60 M5 SMG and 6 Speed Power Clutch kit ! CNS Racing M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 6 12th May 2012 01:18 AM
