An s65 swap is a great idea. Change my mind. - BMW M5 Forum and M6 Forums
 15Likes
post #1 of 41 Old 21st March 2019, 08:23 PM Thread Starter
schadjason
schadjason's Avatar
So I am in the middle of a full teardown on my 105k mile s85. VANOS (or should I say THANOS) decided to mail it in and ate itself (more specifically the outer race and bearing were destroyed).
I pulled the engine and brought it to a shop when I found lots of metal in the oil, partially because they had just done the rod bearings about 10k ago and partially because I don't feel all that qualified to do a full teardown.
Anyhow, the shop has been great to me but they won't use anything other than a brand new vanos pump to the tune of 4200.00. I found some for closer to 3k, but that's not exactly fair to try and force them to use. All said and done the repairs will total about 6k.
Here is where I start to feel froggy. I could source a used s65 for 6-9k, and yes it would be down on power (414 vs 500 as far as HP) as well as torque, it has a low-pressure VANOS system and would be much lower cost (theoretically) in the long term.
My current M5 is a manual, so no issues worrying about DSG/SMG and other than some potential motor mount modifications, it should be a fairly simple swap.
Looking for valid reasons on why/how this is a terrible idea, and it has to be more than just HP. I would have all sorts of room up front for activities (i.e. a supercharger) in the future and would probably drop the gearing down to a 4.10 our back to help compensate for the whopping 86 hp decrease.
So there it is, take your shots gentleman (the harder and more brutal the better).
schadjason is offline
post #2 of 41 Old 21st March 2019, 09:32 PM
Slamfire
Slamfire's Avatar
Comparable S85 used crate motors can be had around 7K usd. Also you know you'll be nearly 100 lbs of torque lower which will hurt with the weight penalty way more than the hp. My only gripe with our cars is lack of torque.
imho the V10 is what makes the car , if you are going to do an engine swap I'd look for a more inventive engine choice.
Viper/SRT10 V10? 6.4 hemi? 5.2 voodoo? LSA?
A S65 M5 is just a fatter E90 M3. as far as having room to supercharge... if you spend the money to swap in a S65(which wont be plug and play) and then supercharge, I'd be surprised if the cost wasn't more than fixing your motor and supercharging it to begin with.
But hey your money your car. Best of luck with whatever you decide to do.
07 6 speed E60 M5
12 6 speed E93 M3
Slamfire is offline
post #3 of 41 Old 21st March 2019, 09:55 PM
triksterut
I think there is a reason that the phrase "swap the motor to save money" isn't used often.
It's something we say to our wives/girlfriends so as to not get in trouble (as much)
triksterut is offline
post #4 of 41 Old 22nd March 2019, 01:13 AM
jcolley
jcolley's Avatar
S65s have the same rod bearing problem. S65s also have main bearing problems the S85 doesn't. I see an equal amount of both to rebuild these days.
mss60 DME for the S65 uses EWS4, E60 CAS module uses EWS3. Not compatible.
jcolley is online now
post #5 of 41 Old 22nd March 2019, 01:20 AM
Bimmer_Pilot
It's going to cost way more than a zero mile S85 off the shelf would cost to accomplish something like that. It's not a direct swap. Custom fab everything mechanical from mounts to transmission to exhaust, intake, chassis modifications for fitment, etc. Custom engine control system. Custom chassis electronics integration. Tuning. You could probably just buy a new car for what that would all cost.
Bimmer_Pilot is offline
post #6 of 41 Old 22nd March 2019, 04:00 AM
terraphantm
LCI CAS module can probably be made to work in EWS4 mode. LCI models use the same part number as the 528/535, which have EWS4.
terraphantm is offline
post #7 of 41 Old 23rd March 2019, 02:39 PM
TexaZ3
TexaZ3's Avatar
That's a terrible idea, honestly.
E36 1999 M3 Coupe Dakar Yellow/Black Vaders
E36 2000 M Coupe Cosmos Black/Black Leather, Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein.
E39 2000 M5 Imola/Black Heritage
E46 2005 M3 Coupe ZCP Carbon Black/Black
E63 2006 M6 Coupe Indianapolis Red/Black/Madeira, Style 343
TexaZ3 is offline
post #8 of 41 Old 23rd March 2019, 03:44 PM
Al59751
Al59751's Avatar
I thought of this while back and i agree its a good idea but not a commitment i recommend. If you plan to keep the car for a long time its a good idea from stand point of reliability.
It wont be cheaper simply because you will have to add dme, harness, programm(you said youre not qualified so possibly pay someone) and gobs of hours to ghetto rig things that are not suppose to be in this chassy. You dont know if hood will even close with the intake. List goes on. S65 would be a cool swap on a wagon but its not practical no matter how you look at it. UNLESS you can get a super good deal on it and have time and experience which it sounds you lack.
PS i would love to see it and it worth a shot. try mpartsworldwide in NJ they have good stock and may get you a good deal on a set
Al59751 is offline
post #9 of 41 Old 23rd March 2019, 06:18 PM
pmalik
pmalik is online now
post #10 of 41 Old 25th March 2019, 12:02 AM
Kermudgen
Well, I'm sure I'm going to get a lot of hate for this... I'm with you.
As much as I love my M6 6sp vert, these cars are fundamentally flawed and I think an engine swap (non BMW) is a brilliant idea. Imagine not dreading thr chime, an engine you're not worried about every time you start it, something that you're not "preventatively" replacing CRITICAL engine components to avoid the grenade scenario, something that at least somewhat RESEMBLES reliability.
Me? I'm plannning to do rod bearings this spring and to drive my car for one summer and if that goes well, maybe a second summer. If, the expected happens and something catastrophic happens to this engine made of glass, I'll NEVER replace it with another s85... Yes it's amazing, yes it sounds glorious, but let's be honest, it's a horribly flawed engine. In 2007 (my MY) it was untouchable in terms or power and performance but reliability, give me a break - the idea of taking this thing on a long road trip is a joke and shame on BMW for what this has turned into. It's a lab experiment that should never have seen production. The S85 is beta at best!!! Vanos pump, vanos solenoids, rod bearings, throttle actuators, injectors, SMG.... What doesn't fail on these that doesn't cost thousands to replace?
Enter the LS SWAP!!! (Yeah I heard the groan...)
IMHO, swapping it with something you know you can count on, is the only thing that makes sense if you love the look, the handling and want SOME reliability. Even an unreliable engine swap would be better than the perpetual expectation of failure of the S85... Alternatively if you have more money than you know what to do with or you're just a masochist who loves to watch your guilty pleasure leave on a flatbed, while you "Burn My Wallet" (BMW life) by all means keep spending money to keep the pin in your S85 grenade, but only just... You'll suffer eventually.
Sloppy mechanics gets 900HP on a with a junkyard LS with a new cam and a turbo, surely a marginal increase in component quality could yeild happiness for E6# owners too.
I'm not naive and of course this is a huge job and subbing this job out to someone would be very expensive but if you're willing to learn and integratethings that were never meant to work together anything is possible, as long as you ignore the naysayers you can make anything happen. FTW! And FBMW! (Last one I'll ever own)
:endsoapbox
Sent from my LG-M703 using Tapatalk
Kermudgen is offline
Tags
s65 , swap
The RUF experience, with a side order of M5 (very large and loads of pics :)) Adam E39 M5 and E52 Z8 Discussion 92 22nd August 2011 08:15 PM
Peter Pan BMW -- bad service, No 1200 mile oil change on 03 jdh E39 M5 and E52 Z8 Discussion 29 21st May 2004 04:49 PM
The RUF experience, with a side order of M5 (very large and loads of pics :)) Adam Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 42 15th May 2003 07:03 PM
a great idea Bigtime007 E39 M5 and E52 Z8 Discussion 4 13th May 2003 05:32 AM
The RUF experience, with a side order of M5 (very large and loads of pics :)) Adam Most Memorable Threads' 30 25th April 2003 02:09 AM
