An s65 swap is a great idea. Change my mind. - Page 5 - BMW M5 Forum and M6 Forums
 15Likes
post #41 of 41 Old 27th March 2019, 03:45 AM
terraphantm
Originally Posted by Ferris View Post
Just so I'm clear we're gonna spend more money than it takes to fix a problem on putting in a different engine with less power, that has it's own problems. Make sense. I guess
If you were gonna do that, go with the S62 reliable and more torque or pony up to an S63 or be a real man and move up to the the S70/2
Big difference is the S65 is much closer to plug and play electrically and mechanically. Like there might be a little bit of tweaking to do Re: EWS, but nothing major. For everything else, you'd basically have to emulate the E6x/E9x DME messages. Of the engines you mentioned, S63 would probably be the most doable, but still would require far more custom work.
Stroker S65 can be interesting since those also fix the rod bearing issues... but you're looking at a huge cost at that point, even without taking into account any custom work you'd need.
On the topic of spending big money to fix deficiencies of the platform, I do wonder if it's feasible at all to modify the S85 heads to accept the low pressure VANOS.
terraphantm is offline
Tags
s65 , swap
The RUF experience, with a side order of M5 (very large and loads of pics :)) Adam E39 M5 and E52 Z8 Discussion 92 22nd August 2011 08:15 PM
Peter Pan BMW -- bad service, No 1200 mile oil change on 03 jdh E39 M5 and E52 Z8 Discussion 29 21st May 2004 04:49 PM
The RUF experience, with a side order of M5 (very large and loads of pics :)) Adam Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 42 15th May 2003 07:03 PM
a great idea Bigtime007 E39 M5 and E52 Z8 Discussion 4 13th May 2003 05:32 AM
The RUF experience, with a side order of M5 (very large and loads of pics :)) Adam Most Memorable Threads' 30 25th April 2003 02:09 AM
