battery discharge info - BMW M5 Forum and M6 Forums
 3Likes
post #1 of 16 Old 18th March 2019, 03:56 AM Thread Starter
flacoramos
Have been doing a bit of troubleshooting on the increased battery discharge messages I've been getting and thought I'd share what I found. The IBS monitors for increased battery drain (>80mA) while vehicle is off and the results can be read with ISTA. So no need to measure current as few other members have been doing lately. See screenshot showing good results for 'only' the last 32 cycles.
flacoramos is offline
post #2 of 16 Old 18th March 2019, 03:56 AM Thread Starter
flacoramos
Another interesting bit is that the DME/IBS calculates a 'startability' threshold based on temperature, battery state of health (this one I haven't figured out how to read...), among other factors, see picture. If the battery level falls below the calculated threshold it will trigger the error, even if there's nothing draining the battery.
The Following 2 Users Say Thank You to flacoramos For This Useful Post:
HM506 (18th March 2019), Skills (22nd March 2019)
post #3 of 16 Old 18th March 2019, 03:56 AM Thread Starter
flacoramos
Now... remember that after the car is parked / shutdown / locked the car itself will wake up after a few minutes and do god-knows-what... ISTA shows a graph of current vs. time showing this being the expected behavior. I believe it's during this housekeeping cycle that the battery charge can fall below the startability threshold (voltage threshold really...), thus the IBS/DME will shutoff power to the radio/cluster/etc. and trigger the increased discharge message on the next cycle.
In my case I've gotten the increased discharge messages only during winters. Which makes sense but car has never failed to start. My battery is about 5 yrs old and testing always showed CCA being ok but not good enough for the IBS it seems (what battery testers think an OK CCA drop is isn't clear...). So I ended up replacing the battery. Will likely have to wait until next year as temps have started to go up around here.
Slamfire (18th March 2019)
post #4 of 16 Old 18th March 2019, 03:14 PM
Slamfire
Slamfire's Avatar
This is a lot of good information, thank you for breaking it all down.
I also have gotten the battery discharge warning in the IDRIVE but have never had issues starting the car. Figured it was a combination of a battery on its way out and the M5 not getting long enough frequent trips for the alternator to do its job well enough. I've taken it out every 4 days or so until it at least gets to operating temp and I haven't had the message come back.
It seems to me these cars really like to be driven. If they sit for too long things start getting wonky.
Slamfire is offline
post #5 of 16 Old 21st March 2019, 10:20 PM
335xi
So, bad programming by BMW?
Basically the IBS does not account for the normal wake up behaviour of the car?
335xi is offline
post #6 of 16 Old 22nd March 2019, 02:44 AM Thread Starter
flacoramos
I'm not following your logic there... If the battery voltage drops below whatever the startability threshold during the housekeeping cycle then it will give you the warning on the next cycle. The most likely cause for a larger than expected voltage drop would be a weak or discharged battery. Also if you've extra electrical equipment on the car then the housekeeping cycle could also turn those loads on and cause a large battery drop. Just guesses here tho.
IMO sure it's a bit conservative with cold temperatures. BUT at the same time it's done it's job right? I've never needed to jump-start the car so...
post #7 of 16 Old 27th March 2019, 07:52 PM
335xi
I am saying it may be oversensitive
On a side note, since it has the capability of commanding certain components to shut down, why doesn't it do that (one at a time) and see which one is misbehaving?
335xi is offline
post #8 of 16 Old 28th March 2019, 05:46 AM
LA Bandit
LA Bandit is offline
post #9 of 16 Old 28th March 2019, 07:00 AM Thread Starter
flacoramos
I don't think that's a true statement. I'd have to look at wiring diagrams, but pretty sure it's all or nothing.
post #10 of 16 Old 28th March 2019, 07:42 AM
LA Bandit
Increased Battery Discharge allmotor_2000 E60 M5 and E61 M5 Touring Discussion 52 10th January 2015 05:28 PM
High discharge - battery warning wickedr E60 M5 and E61 M5 Touring Discussion 0 3rd December 2014 02:20 AM
M5 needs a new battery... Fast.M5 E60 M5 and E61 M5 Touring Discussion 29 27th November 2014 01:34 AM
The dreaded high battery discharge feisaldz E60 M5 and E61 M5 Touring Discussion 13 12th November 2013 07:42 AM
Battery Issues? Found some good info... carolinam6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 14 22nd April 2013 02:01 PM
