S85 High Pressure Vanos Line - BMW M5 Forum and M6 Forums
post #1 of 7 Old 14th February 2019, 09:48 PM Thread Starter
coKeith
I've reviewed the TIS documents on replacing this line and G.A.S.'s docs on the bearing replacement but still left with some questions.
The internal line is fitted from the outside next to the water pump; this is the second "T" connection in the system, the other (for external line) is at the top of the engine. I've yet to remove the pump from below; how much clearance is in there to feed the line down & through? Next, how much are people actually removing to feed the line down? Are you removing the tensioner, face of the water pump and the water lines?
If I wanted to test the lines for leaks w/ the engine open would you just disconnect the accumulator at the bottom and pressure test from there? What kind of leak down would be appropriate?
Thanks!
coKeith is offline
post #2 of 7 Old 14th February 2019, 09:55 PM
m5 deamon
m5 deamon's Avatar
remove two top 10mm bolts from water pump and unbolt the power steering pump and there is all the room in the world to change the high pressure hose
2003 M5 Carbon Black, Black sport interior.
Evolve Alpha N tune, headers,race cats,heads
Rakkiu modified throttle bodies
Schrick cams
e46 m3 oil cooler gulf oil filter housing
Kw v3 with ground control camber plates , Dinan rear sway bar, Beast power brakets
Stop tech st 40 and st22
UUC light weight flywheel 850csi clutch, Evo3 shifter and dssr
Gas mono balls
Rouge wheel studs aluminum lugs
Vorstiner front splitters
Exotics tuning finned diffuser
Euro headlights and taillights with rear fogs
Euro arm rest
40% Lock lsd
m5 deamon is offline
The Following 2 Users Say Thank You to m5 deamon For This Useful Post:
coKeith (15th February 2019)
post #3 of 7 Old 15th February 2019, 12:49 AM
sundaycruzers
I doubt you can get the line in or out without taking pump out. I left line connected to pump and pressurized with air, I could hear the line leaking with pan still on. If that helps
sundaycruzers is offline
post #4 of 7 Old 15th February 2019, 01:33 AM Thread Starter
coKeith
Yes it does help, thanks. What did you use for an attachment to pressurize? I have been looking for something quick/easy at local auto parts but nothing is off the shelf. I assume I could adapt from an air fitting to some sort of banjo fitting? I do see this specialty BMW tool; 83300495130 which would take a few days to get here and might just be a 1 time use for me.
coKeith is offline
post #5 of 7 Old 15th February 2019, 02:31 PM
sundaycruzers
Rubber tip blow gun
post #6 of 7 Old 15th February 2019, 03:54 PM
flacoramos
If engine is open why bother? Remove the vanos pump and replace the hose. You don't want to risk opening the engine again if the hose fails.
As for how to remove the hose I removed the water pump pulley (4 bolts) to remove the hose. I for sure didn't remove the water pump or any water hose.
flacoramos is offline
post #7 of 7 Old 15th February 2019, 04:02 PM
sundaycruzers
I don’t believe he’s pulled anything apart, those pictures are from another thread. And there’s a few more parts to remove than just the water pump pulley, otherwise I completely agree.
Tags
s85 , vanos , vanos test
E60 For Sale: 2x VANOS high pressure pumps - $750 shipped jcolley Parts / Other For Sale or Wanted 7 2nd May 2015 05:36 PM
S85 Vanos High Pressure Pump Duschanio E60 M5 and E61 M5 Touring Discussion 28 21st June 2014 12:28 AM
New vanos high pressure oil pump problem ferretti E60 M5 and E61 M5 Touring Discussion 14 17th July 2012 06:28 AM
