another rod bearing DIY (custom ACL/Lang) - Page 6 - BMW M5 Forum and M6 Forums
 9Likes
post #51 of 58 Old 8th April 2019, 04:00 PM Thread Starter
gpeterson
Originally Posted by Alan Arnesen View Post
How many miles are on those?
104k
Assuming the ones with more wear are the uppers?
Correct
gpeterson is offline
post #52 of 58 Old 9th April 2019, 12:11 AM
dimitri
How many miles are on those? Assuming the ones with more wear are the uppers? I've had my car for about three weeks and the bearings done about 10k ago. Trying to prepare for the future.
The oil viscosity discussion is interesting. I have been working on cars since I was old enough to walk. I have been sailing on ships as an engineer for almost 30 years. The rotation of the crank and friction wedge prevent the crank from touching the bearing. A lower viscosity oil would flow more at a given pressure and provide more cooling. Based on my knowledge start up is when 90% of bearing wear takes place. I plan on installing an accumulator to reduce bearing wear.
The other part of the equation is RPM/Mile. If you are revving an engine to 7k and doing 50mph you have 350,000rev/mile. If you are cruising at 2000rpm you have 100,000rev/mile. As you can see the actual number of rotations the engine makes per our standard unit of measurement is higher. I think for what they are the engine do pretty darn well considering what we are getting out of them
Curious how would you install the accumalotor?
dimitri is offline
post #53 of 58 Old 9th April 2019, 12:22 AM
simonnim
simonnim's Avatar
I thought rpm stands for revolutions per minute. So if you're going 7k, and you're going 50mph, roughly little under a mile per minute why would your engine spin more than 7k? Even if you are considering each bearing as stand alone, that'd still be 7000 x 10? 70,000?
2007 E60 M5 - Indianapolis Red
- Bearings changed at 69,500 with WPC coated 702/703
- RPI scoops & BMC filters
- Charcoal filter delete
- Custom X-pipe
- Resonator Delete
- G-Power section 3
- Gloss black kidney and fender grills
- Euro SMG tune
- ECS stainless steel brake lines
- Castrol SRF brake fluid
simonnim is offline
post #54 of 58 Old 9th April 2019, 12:29 AM
jcolley
jcolley's Avatar
I've been down the thinner oil route and after 14k miles pulled the OEM clearance bearings. Zero improvement, same pattern of wear indicating starvation. I've now had 7 engines apart with larger (more correct) oil clearance bearings and while wear occurs on any plain bearing, the degree is far, far less and the pattern more uniform, indicative of proper lubrication. On these engines, the wear occurs at high RPM as the film depletion rate is greater than the supply rate and the thickness of the oil wedge insufficient. Increasing the oil clearance and staying with the 10W-60 (oddly, per Clevite's recommendation) yields a properly running and wearing motor.
jcolley is online now
The Following 4 Users Say Thank You to jcolley For This Useful Post:
Beniki (9th April 2019), Fiftytwoeighty (9th April 2019), lunarx (19th May 2019)
post #55 of 58 Old 9th April 2019, 01:05 AM
Beniki
Beniki's Avatar
Very good info. Thanks Jim.
In your opinion, the variability we are seeing in bearing wear from car to car, do you think this is down to user treatment, or variations in the bearing clearance?
Beniki is offline
post #56 of 58 Old 9th April 2019, 01:38 AM
Alan Arnesen
Alan Arnesen's Avatar
For 104k miles they don't really look that bad. My bearings were done 10k ago by the PO. Whatever is in there i'm stuck with for now. I agree with you assessment about clearance and starvation. For me the only things I can change is the oil and add an accumulator. There is a thread on the forum, not like it was my idea. Not sure it will solve the problem but I am sure it won't hurt. Somewhere after the oil filter with a solenoid activated by the start command for the engine.
Alan Arnesen is offline
post #57 of 58 Old 9th April 2019, 03:39 AM
flacoramos
I'm not Jim but yes, in my opinion engine to engine variation means you could have a larger clearance engine and experience less wear. Explains the odd one that shows up from time to time showing little wear.
Evidence like this should be in a sticky. Even then people will still claim the issue is due to too thick oil...
flacoramos is offline
post #58 of 58 Old 9th April 2019, 06:11 AM
5MOKED
5MOKED's Avatar
Exactly it’s not all about thick oil.
2010 E60 M5 • Space Grey
5MOKED is online now
Potential Premature Rod Bearing Failures on Early 3.8 Engines due to Oil pump issues Euro-M5 E34 M5 Discussion 2 2nd May 2004 09:13 AM
Selling Custom Audio (3 Amps & Subwoofer) for e39 M5 BeastPower Parts / Other For Sale or Wanted 1 18th March 2003 03:32 AM
Off-Topic but of Interest: Custom M5 Audio System (I am selling) BeastPower Parts / Other For Sale or Wanted 1 18th March 2003 03:30 AM
Custom Carbon Fiber Look M Side Emblems. CountZero Parts / Other For Sale or Wanted 1 16th August 2002 12:33 AM
