SMG Refurbishing - BMW M5 Forum and M6 Forums
 6Likes
post #1 of 61 Old 8th January 2019, 08:31 AM Thread Starter
maddios
SMG Refurbishing
Hey guys, late summer my clutch started slipping under power sporadically, so I figured it must be the throwout bearing, seems i was right as mine has severe wear on its inner bore and it jams up really easily. the clutch itself looks like it's still got tons of life left but I'll replace it and the flywheel anyway, the flywheel has quite a bit of play in it.
A little info about the car, it's a 2006 (12/05 build) 115k miles.
But while I was in there I decided to pull SMG hydraulics apart and replace any o-rings/seals I could find. I went through, measured the sizes of the o-rings and seems like I can find viton ones on mcmaster for all of them except I can't find the piston seals for the selector rods. Anyone know a source for these? I inspected mine and they don't look to be worn but I figure if I can source them for a decent price might as well.
I'm referring to these guys
And now some pictures of what I found inside:
Looks like at some point in the past water had gotten in behind my pump motor
also the motor hub has a ton of wear in it, so I'll have to make a new one
not sure why there was only rust where the hub adapter goes since the rest of the motor face was clean
looks like there was a ton of wear on the motor shaft, and the shaft wasn't fully engaged, i'm guessing getrag made the coupler a little under-size, I will likely make a custom one that's a bit longer
slave cylinder dust boot was fully torn off, looks like these aren't serviceable so I'll have to get a new one
tons of wear on the throwout bearing
but the clutch disks and the pressure plate look like they're in great shape, other than a bit of galling
it's crazy how poor machining quality is on these components, but i guess they're ok enough as at least the o-rings between the shifter valve block and the piston block didn't seem to be leaking, but the shifter block was leaking against the transmission, i had tons of mtl leaking around the top
and here's the scary bit, I need to replace the wires on the shift rod position sensor, but mine has cracks in it, so i'm hoping it doesn't break while i'm working on it (it was working fine when i removed the gearbox). I will likely try to seal it up with potting compound or some sort of RTV once it's back in position so water doesn't try to get into the cracks
btw, how does the accumulator work? at the bottom of the input hole it's blocked off, or are there small holes leading to sideways?
looks like this car had that clutch pressure plate failure where the spacer pucks fall out and start flinging around the bell housing
I'm going to try to document this project here, and I absolutely welcome any advice, except for "don't do this if you don't know what you're doing"
here's a link to the whole image gallery https://drive.google.com/open?id=13g...fVP-e-prcEH9eo
maddios is offline
post #2 of 61 Old 8th January 2019, 08:49 AM Thread Starter
maddios
Is it worth replacing the hydraulic accumulator, mine seems to work still but I did notice that my pressure bleeds off much faster than it used to.
When I got the car 5 years ago (87k miles) the SMG pressure test would end at around 41bar, now it'll barely pass at 31.
I'm assuming it's mostly due to the clutch solenoid leaking down, hopefully replacing its o-rings will help. But maybe it's also due to the accumulator no longer storing as much pressure due to preload leakage?
maddios is offline
post #3 of 61 Old 8th January 2019, 01:41 PM
flacoramos
Jim has mentioned in the past that he had to get custom dies made for the piston and pump internal orings and would not sell them for this reason. But ask nicely anyway? The pump internal oring can also be found on ebay from china I believe - but I'd be cautious with this. The torque spec for the pump screws is not available, and I would question the quality of the ebay oring. No other known supliers at the moment.
Yes the motor coupler has some play built into it to allow for thermal expansion and misalignment and what else. Yours look better than mine with 80k miles btw.
I also had ‘rust’ as you called it. It's probably a mixture of dry grease and coupler shavings – not rust per se.
The throwout bearing was updated to delrin to prevent galling. Rockauto has good if not the best prices for a flywheel (luk) and clutch kit (also luk – you’ll get a sachs clutch in a luk box, includes an alignment tool and pilot bearing).
I didn’t have any MTL leaking on top of the trans, and never seen pics of leaking like yours. Doesn’t matter you’ll get it fixed now .
The accumulator is nothing but a high pressure balloon and a piston separating it from the fluid. You’re seeing the piston face. It’s pushed in by the fluid. No I would not change it. Even if pre-pressure is low it works just fine. And if you decide to change it it’s easy to do from underneath the car. Yes pressure bleeding has nothing to do with the accumulator but leakage on the clutch solenoid orings or solenoid itself.
Easiest way to fix the position sensor wires is to un-pin the connector end and use heat-shrink tubing on each wire. I went crazy on mine and used mil-spec wire, potting compound, etc. If I were to do it again I’d just go with good quality heat-shrink tubing.
Now is the perfect time to open the pump motor and clean all the carbon dust inside. The brushes have some stampings that end up preventing them from sliding freely. Scrape the stampings using a flat screwdriver to ensure brushes slide freely. Dust and brushes catching on their holder seem to be the common failure and not bearing failure or brush wear. Be sure to mark the motor ends with respect to the main body with a sharpie before opening.
Here’s my list of stuff to do when pulling a trans – hope it helps.
https://www.m5board.com/vbulletin/e6...ml#post7536564
flacoramos is offline
The Following 2 Users Say Thank You to flacoramos For This Useful Post:
maddios (8th January 2019)
post #4 of 61 Old 8th January 2019, 09:41 PM Thread Starter
maddios
Thanks for the information.
I sent jcolley a PM but I haven't heard back yet.
When you did yours, did you replace your shift fork piston seals?
I actually got a hold on a brand new smg pump motor. As for the bushing, my bushing is like 2mm too short, that's way too much for expansion, also once it wears, I dont' think any expansion can occur since the motor and the pump kind of bite into their little groove and that's it, mine was almost solid, i had to pull pretty hard to get it off the pump. I'm going to custom make one that's about a mm longer, should bite on the motor a bit better.
You're probably right, upon closer inspection last night I noticed it's almost got the consistency of graphite. but looks like the new motor kits come with a white lithium grease, probably with PTFE, so I guess i'll just go with that when I repack it.
that's a good idea, I might just go this route.
As for the updated throwout bearing with the delrin liner, they're installed totally dry, right?
maddios is offline
post #5 of 61 Old 8th January 2019, 09:49 PM Thread Starter
maddios
oh, wow, thanks for the tip to look on rockauto, their prices on this stuff are WAY lower than everyone else i saw. I was originally going to try to get them from FCP but, not at that premium.
It's too bad they don't carry some of the other stuff I need, like the bearing sleeve or slave cylinder.
maddios is offline
post #6 of 61 Old 8th January 2019, 11:53 PM
flacoramos
Best way to contact Jim is through facebook. He has too many PMs.
I did not replace the fork piston seals.
Yes the delrin bearing is installed dry.
Rockauto always has a 5% off coupon going on, just google it.
For BMW-specific parts I typically use http://www.bmwdirectparts.com/ or http://www.bmwpartshub.com/
On RARE occasions FCP or ECS are worth their premium.
post #7 of 61 Old 13th February 2019, 02:07 AM Thread Starter
maddios
So I ended up going a different route as far as acquiring the rebuild/refurb kit.
I randomly found a company (https://mlreng.com/) via ebay which sold an SMG pump motor kit and shot em off a message asking if they were able to sell me just the seal set for the pump since I had randomly already bought just the motor itself, without any of the other parts.
I was very surprised to find that not only did the guys sell the parts separately, BUT they actually had all the rest of the seals for the whole SMG hydraulic unit. So I went ahead and purchased a complete kit from them and it has just arrived on monday! The kit looks really well put together, super easy to figure out what o-ring is for what purpose, etc.
The kit I bought from them included the all parts from the SMG pump kit, all the o-rings from the shift solenoid block (including all of solenoid o-rings) and the clutch solenoid o-rings.
I haven't had a chance to start the rebuild, when I do I'll post detailed photos of the kit and all of the process itself.
PS: I was originally going to buy all the o-rings from mcmaster, but they didn't actually have exact sizes for some of the o-rings I needed, so that's why I decided to just get a pre-made kit.
maddios is offline
post #8 of 61 Old 13th February 2019, 02:10 AM Thread Starter
maddios
A quick question for those who have done this before, what would you recommend I used to wash the aluminum parts and solenoids in (I'm going to use a parts washer and some soft nylon brushes)?
I was thinking of using water and dish soap since that shouldn't etch the aluminum bores, but I'm not certain that's the best thing for the job.
maddios is offline
post #9 of 61 Old 13th February 2019, 04:16 AM
Crisnla1
Crisnla1's Avatar
Crisnla1 is offline
post #10 of 61 Old 26th February 2019, 10:59 AM Thread Starter
maddios
Here are some pictures of the kit provided by http://MLReng.com:
In this photo are the items which are part of the SMG motor pack, I got just the hardware kit since I already had the motor. very nicely organized.
In this photo are the nicely packed o-rings for the hydraulic shifter unit (on top of the gearbox) it came with every single o-ring to do the job, including all of the solenoids and 8 shifter piston block o-rings, as well as the seals for the shift position sensor.
At the top is a prototype replacement wiring harness for the shift sensor, since this is a prototype it's all the same color and the wires are a bit stiffer than stock but they're very high quality, the real one will likely be modified a bunch, but this one worked for me perfectly as is. the insulation on these wires was VERY strong, and it comes with the whole connector pre-assembled.
Here are some close up shots of the replacement wiring harness
maddios is offline
Tags
smg , smg refurb
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Refurbishing Items Q's captain_anonymous_2003 E39 M5 and E52 Z8 Discussion 0 12th February 2011 02:50 PM
2000 M5 refurbishing phase 1 complete -Pics TheEdge E39 M5 and E52 Z8 Discussion 8 10th August 2010 10:32 PM
Post wheel refurbishing care TheEdge E39 M5 and E52 Z8 Discussion 3 21st July 2010 09:19 PM
Refurbishing your own wheels AndyE E34 M5 Discussion 5 15th April 2006 07:31 AM
