SavageGeese reviews the E60 M5 - Page 6 - BMW M5 Forum and M6 Forums
 45Likes
post #51 of 71 Old 3rd December 2018, 09:50 PM
V10HOWL
Originally Posted by Fiftytwoeighty View Post
150,000+ miles of having fun.
And Iím going to leave this here:
Awesome! Was that 2nd gear after merging onto 73? What a long gear!
Looks like you have the same slight rubbing issue I have over big bumps at highway speed haha. You try dialing in more negative camber? You're running 305/30/19 in the rear? I'm running 295/30/20 but Pilot Sport 4S'.
V10HOWL is offline
post #52 of 71 Old 3rd December 2018, 10:31 PM
flacoramos
Originally Posted by Obioban View Post
Camber does increase faster than body roll, but it still doesn't get you enough for track use-- but camber plates could also sort that. More to start with, and then more still under cornering load.
That depends on suspension geometry which I don't think anybody knows. Stock camber is negative to start with. Then if camber increases faster than roll that means camber can only increase as the wheel compresses (talking only about the outside wheel just to be clear). If the tire has even more neg camber while turning why would the outer shoulder take a beating? Something doesn't sound right.
As camber is defined with respect to a vertical line (not the car vertical plane which changes as body rolls) speaking of camber increasing faster than body roll is not an accurate term. We may be confusing camber with the angle between the tire and the body vertical line.
flacoramos is offline
post #53 of 71 Old 3rd December 2018, 10:36 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
An easy roll on 3rd gear, going into the on-ramp. I wasn't on the throttle until I knew I had the "all clear" from the rear. You can see me match my speed to the blue Taco, before I decide merge.
My co-worker, in his McLaren 650s, was following/catching us.
Yes, I'm rubbing my 305s a little -- just too lazy to raise adjust my coilovers for the wheelset I'm currently running.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =162,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; MCS 2WNR motorsport coilover, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Nuke Performance fuel rail and pressure regulator, Carbon Fiber CSL intake; Lifeline Zero 360 FIA 3.0kg Novec fire suppression; Cool Shirt Pro Air/Water system; Euro RestoMod track car: caged, 6 point Schroth FIA harness, FIA Sparco Ergo & Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x9 BBS Style 42 w/Michelin Cup 2; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
Not-spec e30 racercar!!! Fully caged for wheel 2 wheel racing
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
post #54 of 71 Old 3rd December 2018, 11:41 PM
Obioban
Obioban's Avatar
It's actually super easy to check without knowing anything about the geometry-- watch the camber change as you lower the car.
The outside of the tire takes a beating on track because the tire is rolling over. You can also decrease it by increasing pressure, so it rolls over less.
Obioban is offline
post #55 of 71 Old 3rd December 2018, 11:59 PM
flacoramos
Humm... Yes camber increases as suspension is compressed. But you claimed it increases more than body roll (during a turn). THAT is what I don't know. If camber (with respect to a true vertical - not the car vertical) stayed negative then the outer shoulder would not suffer.
post #56 of 71 Old 4th December 2018, 06:27 AM
iDev326
iDev326's Avatar
Originally Posted by Busta View Post
Anyone know a place/person near Orange County, CA that can Euro tune? thanks
If you're looking for the Euro SMG tune, I've done a few for local owners here in LA. Message me and we'll work something out.
iDev326 is offline
The Following User Says Thank You to iDev326 For This Useful Post:
Busta (4th December 2018)
post #57 of 71 Old 4th December 2018, 01:09 PM
Obioban
Obioban's Avatar
That's not correct-- you're assuming infinitely stiff tire sidewall. You can see this by altering how beat up the side wall gets by tweaking tire pressures.
From BMW's training materials on the front suspension geometry used in the e60:
The true benefits of the double-pivot suspension become more evident during turns.
On a traditional single-pivot design, the camber and caster remain static during steering
maneuvers. On a vehicle with positive caster, the wheels tend to “flop over” during turns.
This situation reduces the tire contact area with the road and increases the effort
required for steering wheel return. The steering offset (scrub) also remains fixed which
has a negative impact on steering wheel return as well.
The double-pivot design allows the “imaginary” lower pivot point to change relative location
during turns. The tire which is on the outside of the turn is carrying the majority of
the load. Therefore it is the outside tire which must have the most contact area with the
road surface.
On a turn, the double-pivot design causes the caster and camber on the outside wheel
to become closer to zero. This optimizes the “contact patch” between the tire and the
road greatly enhancing handling characteristics.
The body roll is also reduced by the caster change towards zero. One of the other
benefits of this arrangement is the variable steering offset. The variable steering
offset during turns provides for better “returnability” of the steering wheel.
That said, with most setups, the lower the car the worse the camber curve (unless corrective measures have been taken). So, if you've lowered the car, it is possible the camber isn't keeping up with the body roll. I still think it's unlikely, though-- a sporty car where the camber doesn't keep up with the body roll would be pretty ineptly setup, and BMW is not inept at chassis setup :P
Obioban is offline
post #58 of 71 Old 4th December 2018, 02:41 PM
Skills
Skills is offline
post #59 of 71 Old 4th December 2018, 03:56 PM
flacoramos
Ah yes, I'm ignoring tires and focusing on camber alone. Now the highlighted sentence above shows that camber does not become more negative during a turn (faster than body roll as you stated earlier). As written it implies exactly the opposite. It goes from negative towards zero: ie for a given turn the body roll angle is greater than camber gain (in the negative camber direction) on the camber vs. suspension travel curve.
Originally Posted by Skills View Post
Thread jacked again... lol
Happens
post #60 of 71 Old 4th December 2018, 08:27 PM
Skills
Happens
Yeah... cracks me up how threads evolve.
I am a repeat offender for sure.
Skills is offline
Owner of E60 M5 and F10 M5 reviews the two directly ktranm3 E60 M5 and E61 M5 Touring Discussion 7 22nd February 2013 05:09 PM
BMW M5 E60 V10 compared with the M5 F10 V8 TwinTurbo from latest reviews Gustav F10 M5 Discussion 6 28th September 2011 03:05 PM
BMW M5 E60 V10 compared with the M5 F10 V8 TwinTurbo from latest reviews Gustav E60 M5 and E61 M5 Touring Discussion 19 25th September 2011 04:11 AM
Reviews of the E60 M5! Mr Janne E60 M5 and E61 M5 Touring Discussion 67 28th September 2006 01:33 PM
Downloads: 2 x Australian Reviews on E60 + M5 news enots E60 M5 and E61 M5 Touring Discussion 11 9th August 2003 11:57 PM
