E60 M5 2008 transmission oil change - BMW M5 Forum and M6 Forums
 2Likes
  • 1 Post By flacoramos
  • 1 Post By //Martuci
post #1 of 6 Old 29th October 2018, 09:00 AM Thread Starter
Vugar Aliyev
Hi all.
I have question about transmission oil change.
1. After/before change tranmission oil can we do any action on ISTA-D?
2. Is transmission/clutch adaptation necessary after performing a gear oil change? Or it's just a simple drain and fill operation? Thanks!
Vugar Aliyev is offline
post #2 of 6 Old 29th October 2018, 04:24 PM
flacoramos
SMG right? You need inpa or ista to run the cooler pump to empty the cooler and lines. You also need to run again to make sure new oil fills the cooler and lines before checking oil level.
No clutch routine needed.
flacoramos is offline
post #3 of 6 Old 30th October 2018, 11:05 AM Thread Starter
Vugar Aliyev
Hi Flacoramos
Thanks for reply.
yes SMG. Our official dealer said that if we do ista to run the cooler pump to empty it's may be harmful. because pump will work without oil,
How dou you think? Can i change oil ? without ista or just unload oil and full up ?
post #4 of 6 Old 30th October 2018, 02:03 PM
//Martuci
//Martuci's Avatar
Tell your dealer to open up their thick books and read before they speak In case this is too demanding, they can also check the procedure over here https://www.newtis.info/tisv2/a/en/e...arbox/1L8Q8CjP
In real life, I turned the pump ON not more than 4-5sec and all the oil from the cooler just blast out of the drain in a second. It seems pump is pretty powerful.
Good luck and keep an eye on them!
//Martuci is offline
post #5 of 6 Old 30th October 2018, 03:10 PM
ctek
ctek's Avatar
How about manual transmissions? Simple drain and refill?
ctek is online now
post #6 of 6 Old 31st October 2018, 01:10 PM
M V10 Power
M V10 Power's Avatar
Yes that is correct you got it
M V10 Power is offline
2008 E60 m5 oil change and smg fluid NasNyc E60 M5 and E61 M5 Touring Discussion 1 19th March 2013 09:03 PM
To [change] oil now or to [change] oil later gherardini E39 M5 and E52 Z8 Discussion 12 3rd November 2007 05:46 PM
OIL OIL OIL OIL OIL OIL sulaiman E60 M5 and E61 M5 Touring Discussion 9 13th March 2006 01:30 PM
Change Vanos+change transmission????? Dokra E60 M5 and E61 M5 Touring Discussion 14 13th November 2005 04:53 PM
Transmission and Diff Fluid Change/Coolant Flush/Change - When? x703jko E39 M5 and E52 Z8 Discussion 3 3rd April 2004 12:51 AM
