Battery causing multiple errors - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 12 Old 29th September 2018, 01:12 PM
Ferris
Originally Posted by Craze View Post
Trickle chargers and not registering batteries wreck batteries
^This but also no harm checking running voltage/alternator output.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is online now
post #2 of 12 Old 30th September 2018, 12:12 AM
5MOKED
5MOKED's Avatar
Check your alternator! Had the same exact issue on my old e90. These cars will throw multiple codes when voltage goes haywire. Changed battery and it worked for 1 day and died again. Found out it was my alternator
5MOKED is offline
post #3 of 12 Old 30th September 2018, 10:16 PM Thread Starter
mfettara
mfettara's Avatar
Thanks for the tips.
w days ago when I came home from changing the battery, it registered 12.71V, today (2 days later) 11.7 V, something is draining it so I put t back on the charger for now.
Alternator running voltage is 14.7V
Any further ideas ?
Sent from my iPad using Tapatalk Pro
Marc
2005 E60 Grey ///M5
Bikes : BMW S1000RR Track / BMW S1000R / BMW S1000XR
Previous:
99 Carbon Black ///M5
BMW K1300R / BMW K1200R
mfettara is offline
post #4 of 12 Old 1st October 2018, 01:50 AM
Ferris
Diagnosing sleep mode is a pain the ***..
My You can measure draw across a circuit by using the fuse a shunt, but you need to wait for the car to sleep. IIRC Inpa can force it to sleep but I haven't looked at that for a while.
2001 E39 M5
2010 E60 M5
2008 E90 335xi
post #5 of 12 Old 1st October 2018, 06:40 AM Thread Starter
mfettara
mfettara's Avatar
Thanks Ferris, I will try to pinpoint the culprit !
Marc
2005 E60 Grey ///M5
Previous:
mfettara is offline
post #6 of 12 Old 3rd October 2018, 06:12 PM Thread Starter
mfettara
mfettara's Avatar
Well it took 2 days, so next alternator and regulator I’m afraid !
All goes fine as long as I drive at a reasonable speed. Today the voltage dropped when relying more heavily on power steering while parking in the garage .
Marc
2005 E60 Grey ///M5
Previous:
mfettara is offline
post #7 of 12 Old 14th October 2018, 05:27 PM Thread Starter
mfettara
mfettara's Avatar
So I changed the alternator/regulator and all seemed fine u til I left the car parked overnight and got a Left rear fog light warning and subsequently a Battery drain message (but the car did start). Starting to be fed up spending significant $ not solving the problem...
I am thinking about 2 possibilities :
1. Something is not “going to sleep*» and somehow draining the battery (the voltage does seem to drop about 1V in a day).
2. IBS sensor could be faulty
Has anyone had those related issues and what was the culprit?
Thanks in advance
Best regards
Marc
2005 E60 Grey ///M5
Previous:
mfettara is offline
post #8 of 12 Old 10th June 2019, 07:10 PM Thread Starter
mfettara
mfettara's Avatar
Battery drain but where ?
Thanks in advance
Best regards
Following up on the above :
My local guy replaced the battery with an Exide AGM 80 aH at the time I had the Eisenmann and the stage 1 mapping done about eight months ago.
That battery has died about 2 weeks ago although I kept the car on a CTEK trickle charger with the AGM program.
Saturday I decided to analyse the source of the drain using the Ampère meter / pulling fuses method in the following sequence :
1. removed the old battery and replaced i with the original OEM I had removed as preventive maintenance end of 2016 (I had that since then on a CTEK as well)
1a. let that battery replenish overnight with a CTEK on the engine bay points
2. plugged a charger to the engine bay boost points
3. Used jump cable to short the battery negative terminal to a bodywork negative point near the trunk fuse box
4. Unscrewed the trunk negative battery lead au the bodywork nut and plugged my amp meter between the lead end and the bodywork nut.
5 Manually locked all dors, boot lid and both engine bay latches
6 Locked the car with the remote
7. started measuring the current draw as follows (filming the amp meter with my phone) :
0'00 : 758 mA
0'08 : 701- 707 mA
1'44 : 683 mA
2'20 - 2'40 : 164 mA
2'54 : 20 mA
14'31 : 4 mA (fluctuating then on between 3 and 4 mA)
then 2 time laps until my phone died
Yet : I have lost 4% since the past 15 hours (see pic) :
Question 1 : where is my battery drain ?
Question 2 : should I re-register my "old battery" ?
Thanks for any pointers you may have.
Marc
2005 E60 Grey ///M5
Previous:
mfettara is offline
post #9 of 12 Old 10th June 2019, 08:45 PM
flacoramos
Pics not working for me. But 4 mA after full sleep is very reasonable. And yes you can re-register an old battery (I'd say you should register anytime you change the battery).
Also as I posted on another thread you can query the history as the car keeps track of the last 32 or so cycles for excessive discharge.
flacoramos is offline
post #10 of 12 Old 10th June 2019, 08:49 PM
flacoramos
Just to make sure you removed the jumper cable from batt neg to body after you installed your ammeter and hooked the cable back correct?
Multiple Errors, Common Sensor? Jennifer-in-Seattle E60 M5 and E61 M5 Touring Discussion 16 25th March 2018 07:27 AM
Multiple errors please help !! Ruthless E60 M5 and E61 M5 Touring Discussion 2 31st January 2016 05:21 PM
Multiple dash lights/errors after seat removal Raptor6702 E60 M5 and E61 M5 Touring Discussion 8 2nd May 2015 08:00 AM
Help!! Multiple errors, Level control, PDC, Flat tire monitor, Transmission pn2009 E60 M5 and E61 M5 Touring Discussion 6 25th June 2011 04:15 AM
Low Battery Causing RED COG????? flaury23 E60 M5 and E61 M5 Touring Discussion 8 24th June 2011 08:37 PM
