No Spark on Bank 1 - Ionic unit?? - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By TurboHugh
LinkBack Thread Tools Rate Thread
Old 10th September 2018, 04:14 PM Thread Starter
WhiteMonster
WhiteMonster's Avatar
Recently had an issue with the vanos oil line bursting, causing the vanos oil pump and solenoids to have issues. I replaced the vanos oil line, cleaned out the system, cleaned the pump and vanos solenoids which are now in working order. Gave the motor a crank, it started the first time (rough as I didn't do the vanos bleed yet). HOWEVER, after turning off the motor the first time, it will no longer start back up. After multiple checks (no relevant error codes), I can see there is no spark on Bank 1. I replaced the ionic control unit, still no spark on bank 1. I swapped sides with bank 2's ionic control unit which had spark and still no spark on bank 1. Any suggestions or things I can check? It is currently not starting at all.
WhiteMonster is offline
Old 10th September 2018, 10:01 PM
TexaZ3
TexaZ3's Avatar
If error didn't travel with ionic then its not ionic, right?
E36 1999 M3 Coupe Dakar Yellow/Black Vaders
E36 2000 M Coupe Cosmos Black/Black Leather, Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein.
E39 2000 M5 Imola/Black Heritage
E46 2005 M3 Coupe ZCP Carbon Black/Black
E63 2006 M6 Coupe Indianapolis Red/Black/Madeira, Style 343
TexaZ3 is offline
Old 11th September 2018, 12:13 AM Thread Starter
WhiteMonster
There is no errors, but yes it didn't follow when swapping the ionic units. I'm thinking it may be a ground issue or something else I'm not thinking about with the ionic control units? Also, could it be anything else?
Old 11th September 2018, 05:18 PM
TexaZ3
TexaZ3's Avatar
Could be as simple as faulty coil pack. Did you try swapping those?
TexaZ3 is offline
The Following 2 Users Say Thank You to TexaZ3 For This Useful Post:
WhiteMonster (11th September 2018)
Old 11th September 2018, 06:05 PM Thread Starter
WhiteMonster
Not yet, but checked cylinders 1, 2 and 3 and theres no spark on either. Checked cylinders 6, 7, 8 and all have spark. I can try swapping some coil packs around and seeing if it concludes something.
2008 E60 M5
2013 750i xDrive
Old 13th September 2018, 07:30 AM
TurboHugh
TurboHugh's Avatar
Ground or harness issue #MyVote
2003 M5 Sterling Gray Metallic
BMWmregistry.com Member # 13792
NccBmwCCA Member # 5339
TurboHugh is offline
Rate This Thread
E63 Want to Buy: ionic control unit& power power steering pump robertstrendell Parts / Other For Sale or Wanted 0 24th April 2016 05:25 AM
Ionic current control unit part number huh?! E60 M5 and E61 M5 Touring Discussion 5 23rd March 2015 03:57 AM
Ionic Control Unit-replacement M5knockout E60 M5 and E61 M5 Touring Discussion 4 21st March 2012 11:42 PM
Can someone kindly say which one is bank 1 and bank 2 on engine blitzkrieg E39 M5 and E52 Z8 Discussion 3 17th June 2005 07:21 PM
