Increased Emissions - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By godnf8
post #1 of 10 Old 3rd September 2018, 09:58 PM Thread Starter
lopealle
Increased Emissions
I was driving the car and all of a sudden I received a CEL, Increased Emissions, and a limp mode fault. I do have the fault codes. The drive home was extremely slow. I was if it didn't have enough power to go through the gears. When I would pull out into to traffic I was able to go as fast (maybe slower) as a 18-wheeler would when pulling into traffic.
P0305 Cylinder 5 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0300 Random Multiple Cylinder Misfire Detected
All help would be greatly appreciated.
lopealle is offline
post #2 of 10 Old 4th September 2018, 04:31 PM
flacoramos
Just a guess since it's all in one bank, ionic module. Swap modules between banks and see if error follows the module.
flacoramos is offline
post #3 of 10 Old 4th September 2018, 07:13 PM Thread Starter
lopealle
Is there a DIY on how to do it? I looked on youtube and didn't see anything.
lopealle is offline
post #4 of 10 Old 4th September 2018, 10:42 PM
godnf8
godnf8's Avatar
See if this helps any. Another member will need to confirm if this is correct since I've not needed to mess with mine yet, not sure.
Believe these are the ones folks are suggesting to swap to see if the codes change banks after swapping and then clearing codes. If it does, you know you got a bad one.
https://www.newtis.info/tisv2/a/en/e...bank-2/1qP23f6
2008 BMW M5 E60 Current DD
godnf8 is offline
post #5 of 10 Old 6th September 2018, 04:12 PM
Domrepkid
Domrepkid is offline
post #6 of 10 Old 6th September 2018, 04:22 PM
godnf8
godnf8's Avatar
Originally Posted by Domrepkid View Post
what device do you use to read codes?
I use INPA on a surface pro to pull and reset currently and then websites to determine what code means.
You can also use scanning tools like this one, though I'm sure there are cheaper alternatives
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
godnf8 is offline
post #7 of 10 Old 6th September 2018, 11:49 PM
Com6
Com6's Avatar
I do confirm, those are the ionic modules as suggested by Flacoramos, this is likely to be the culprit. The unit is controlling the spark plugs' coil. A defficiency of the ionic module will result on a full bank misfiring.
Com6 is offline
post #8 of 10 Old 12th September 2018, 08:19 PM Thread Starter
lopealle
I no longer have the scanner that I borrowed
I'll have to check it out.
I have will hopefully have someone looking at it in the next or so. I will throw that bug in their.
lopealle is offline
post #9 of 10 Old 13th September 2018, 08:58 AM
Domrepkid
ok i use the carly app and adapted to clear codes and check them as well
dont know if that would be of some help.
post #10 of 10 Old 13th September 2018, 05:49 PM
cold m3
cold m3's Avatar
That will work and reads specific BMW codes.
Current: 6MT 2008 LCI E60 M5 (Interlagos Blue)
Last: 6MT Super Charged E46 M3 (Carbon Black) (6 years of ownership)
Instagram: Cold_M3
Photos of My ///M5
cold m3 is offline
Increased emissions alert joshkerr E60 M5 and E61 M5 Touring Discussion 46 21st October 2009 10:23 PM
E85 fuel-"Increased emissions- Service Engine Soon" N30EW E60 M5 and E61 M5 Touring Discussion 16 20th January 2007 07:24 PM
Transmission fault and increased emissions - Related? NavM3/5 E60 M5 and E61 M5 Touring Discussion 1 30th November 2006 06:47 PM
Engine Malfunction: Increased Emissions AND reduced power! V10BEAST E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 7 2nd November 2006 03:39 AM
Feedback on 'increased emissions' warning? ttm6 E60 M5 and E61 M5 Touring Discussion 20 25th July 2006 01:52 AM
