Transmission bleed procedure question. - BMW M5 Forum and M6 Forums
post #1 of 2 Old 3rd July 2018, 05:33 AM Thread Starter
Mlrsguy1982
Mlrsguy1982's Avatar
I have been trying to look all over the board for anything related to bleeding procedures. Everything I have found was through INPA etc. Is it possible to manually bleed the system while the transmission is out of the vehicle?
Currently trying to fix a leaky rear main, but since the transmission is out, I figure I would start cleaning things and replacing my clutch control valve since everything else is 90% new. Another question would be, does a clutch slave cylinder necessarily have to be leaking from inside the transmission to determine if it's bad or not. I'm sitting here inspecting everything, and it all looks clean and dry other than the rear main oil that is on the bottom of the bell housing. Sorry if this seems out of the ordinary, but trying to learn as much as I can here lol
Mlrsguy1982 is offline
post #2 of 2 Old 3rd July 2018, 08:25 AM
Hasan Shaikh
Hasan Shaikh's Avatar
I have always drained and put in new fluid. Never done any special procedure. Just make sure the transmission is level with the ground so that you don't over fill.
Hasan Shaikh is offline
DIY: VANOS Bleed and Test Procedure in ISTA/D Sophie E60 M5 and E61 M5 Touring Discussion 12 14th July 2018 02:40 AM
Transmission bleed: anyone know what this does m5rbk E60 M5 and E61 M5 Touring Discussion 6 27th October 2013 06:53 AM
SMG pump replaced and now won't initiate bleed procedure?? SpeedAgent E60 M5 and E61 M5 Touring Discussion 6 20th February 2013 03:23 PM
Coolant Bleed procedure? TIS instructions? 2strokecoldsmoke E39 M5 and E52 Z8 Discussion 11 23rd June 2011 06:26 AM
Question - convert to Motul 600 / clutch bleed? Just Right E39 M5 and E52 Z8 Discussion 0 12th June 2006 05:00 AM
